Carpe manana
![]() ![]() Join Date: Dec 2010
Did the metal tailgate strip use some sort of weatherstripping?
I saw a members Blazer today and his has a piece of what looks like weatherstripping running across the outside surface of the metal tailgate strip that seals against the hatch. Did GM ship K5's with this "weatherstripping"?
Thanks, Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
2WD Jimmy
![]() Join Date: Mar 2005
Re: Did the metal tailgate strip use some sort of weatherstripping?
Nope. Rubber weatherstrip is only on the hatch. It's not uncommon to see where owners have put on some additional rubber in places to try and supplement the old leaking gaskets.
Carpe manana
Thanks!
SKINNY TIRES RULE!
Mine has a a a rubber seal along the inside edge of the tailgate under the carpet strip. It also has similar seals & strips up the C pillars.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
Mine had a strip of rubber between the bed and chrome molding holding down the rear carpet.
#6 | |
Carpe manana
SKINNY TIRES RULE!
I don't believe the top strip did. A PO put some foam stripping on mine, but it doesn't look original.
Carpe manana
Thanks - that's probably what I was looking at also: a PO putting some weatherstripping across the top strip. Pete
SKINNY TIRES RULE!
I never removed mine because I figured it may add a little more seal from exhaust fumes. When/if I restore the truck I don't know if I'd put it back on.
Just looked at the lmc catalog. No seal on the pic. Just the window stop screwed to the tailgate.
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Yes there is an actual piece of weather stripping that goes in that channel.
Side channels. ![]() ![]() ![]() ![]() ![]() I got mine at GMC Pauls
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
He was asking top of tailgate but thanks for those pics. Mines missing the side channels and I removed the carpet and lower strip to rhyno line my tub. Probly get that some this summer. Wonder if the still sell tjose side moldings. My tailgate rattles s lot without it.
#13 |
mental note...read post fully.
Mine has no weather stripping there, just the metal strip the hatch seals against.
#14 |
I just took one off a 1972 blazer out in a junk pile and there was nothing inside it.
#15 |
(Not Mine) This was a great way to fill the gap if you don't have the original carpet strip.to seal off any exhaust that might come in the back. I saved these photo's...some one put a lot of time in making this Blazer better than new.
#16 |
Looks like that would Work Pretty good.
#17 |
Carpe manana
Good info guys - thanks for sharing
