Old 12-30-2013, 02:33 PM   #1
Firstgenfan
Is it worth boxing the frame?
Thinking whether or not I should box the frame on my 53. It's boxed to the firewall right now. Motor is going to be a 6.0 LS style motor with probably just a cam. It might be around 400 crank horse or so. Any suggestions? Truck is going to be just a cruiser
Firstgenfan is offline   Reply With Quote
Old 12-30-2013, 03:50 PM   #2
Highsider
Highsider's Avatar
Re: Is it worth boxing the frame?
From the search feature at the top.
This may help:
http://67-72chevytrucks.com/vboard/s...d.php?t=554860
Jimi J from I-Oh-Way
'57 Panel 3105
Met this deer...
Roof Swap on my Panel
Jim's Bread Truck
Highsider is offline   Reply With Quote
Old 12-30-2013, 07:06 PM   #3
vht
Box it. I did mine, didn't want to take the chance.
vht is offline   Reply With Quote
Old 12-30-2013, 07:54 PM   #4
Firstgenfan
Thanks guys. I said screw it and started the rear... should be done tomorrow from the cab back and have my pieces cut for under the cab. I'd be a lil farther ahead had my oxy/acetylene torch not been empty.
Old 12-31-2013, 10:40 AM   #5
MARTINSR
MARTINSR's Avatar
Unless you are running a BIG motor and BIG tires, personally I say it doesn't need to be done. And be very careful doing it, you CAN knock that frame out of square welding too much too fast.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 12-31-2013, 11:49 AM   #6
fabguy
Elev8r Man
fabguy's Avatar
Brian
I agree
1955.2 C4 Carry-all / Suburban ---> 55.2 Build Thread!!
1958 Fleetside SWB ---> 58 Fleetside Build thread
1939 2 door sedan
My F.B. project page.
fabguy is offline   Reply With Quote
Old 12-31-2013, 01:09 PM   #7
1958Warrior
1958Warrior's Avatar
I boxed my frame around my( No Limits ) Camaro clip, to right under my front cab mounts, this was to add strength to the clip. about 13" total
Also, boxed the frame after C-notch the rear, went from the shock cross mount forward about 20"
I may add another plate (12") just in front of the front rear spring perch and crossmember for a little more strength .
But I think boxing the whole frame is overkill for a driver.
A few plates added to the frame will stiffen it a lot.
You'll be breaking the tires loose and smoking them for some red light fun.
If you plan on putting on some slicks going to a sticky track and doing hole shots I would say box it
1958Warrior is offline   Reply With Quote
Old 12-31-2013, 01:13 PM   #8
Kabwe
Certified Car Nut
Kabwe's Avatar
Boxing the frame is overkill for a street driven car. For 400 horses I sure would not worry about it. Box the frame where you IFS goes. From the front to about the fire wall is typical Why? Because the original frame was a c channel and designed to flex and help the straight axle suspension. Once you install IFS there is no longer a need for the frame to flex. It is actually better to have a boxed and stiff frame in that area and let the IFS do its job.
That being said I did box my frame from the rooter to the tooter. Why because I like the way it looks and plus I'm known to it a little nutty.lol
Kabwe is offline   Reply With Quote
Old 12-31-2013, 01:41 PM   #9
Firstgenfan
Rear is tacked in on both sides and I have the pieces cut for under the cab. No turning back now! I MIGHT turbo this truck down the road so I figured I'll just do it and it's done. Thanks for all the responses!
