Old 12-30-2013, 04:00 PM   #1
Claytona08
Claytona08's Avatar
Hidden Receiver hitch
Got a new project I am about to work on and thought I'd share. I plan on keeping my receiver hitch but I don't want it to be hanging below my bumper. I plan on relocating it so that it is centered behind my license plate bracket. Here is a sketch I did.
http://67-72chevytrucks.com/vboard/s...d.php?t=580955
http://youtu.be/JYoQJYTXKqI
1984 Chevrolet Scottsdale C10 "Project Platinum C10"
1971 Chevrolet Chevelle "Project Car"
Claytona08 is offline   Reply With Quote
Old 12-30-2013, 04:26 PM   #2
wraprail
wraprail's Avatar
Re: Hidden Receiver hitch
Thats been done a couple times. Lol get a flip down license bracket from an Impala or 82-92 Camaro. There really is no need to use any plate or mount to the bumper. Mine I just cut the hole in bumper with a hole saw for hitch mount. Actually used a factory Suburban hitch fit perfect.
wraprail is offline   Reply With Quote
Old 12-30-2013, 04:45 PM   #3
Claytona08
Claytona08's Avatar
Yeah I thought about getting a flip down bracket like I have on my Chevelle. The LMC rear license panel I have bolts into the mounting holes on the bumper but I would need to cut a hole in it to flush mount my hitch.
Old 12-30-2013, 04:59 PM   #4
05duramaxhd
or you could get a hitch that is made for a roll pan.
05duramaxhd is offline   Reply With Quote
Old 12-30-2013, 05:04 PM   #5
Claytona08
Claytona08's Avatar
Well I don't think I'll really ever need a hitch for my truck but since it already had one when I bought it I thought I'd modify it so if I ever do decide to pull something I'll have one.
Old 12-30-2013, 07:20 PM   #6
Blackpony
Blackpony's Avatar
I am planning to do the same thing with my truck soon. I was looking to do a flip tag, but having a receiver piece that holds the tag is actually a really good idea! Thanks for that haha
Blackpony is offline   Reply With Quote
Old 12-30-2013, 07:24 PM   #7
Keith Seymore
Keith Seymore's Avatar
I used the flip plate holder from a Chevelle as well.
My hitch is home made.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 12-30-2013, 07:56 PM   #8
Claytona08
Claytona08's Avatar
No problem, lol
K
Looks good Keith. Thanks for the pics.
Old 12-30-2013, 10:46 PM   #9
cool68
attached are pics, some poor quality, of set up on rear bumper of my '76 Fleetside longbed. Just had truck painted so, sitting on an orange parts dolly. I am looking to swap this bumper set up locally for a good stock bumper. do not plan to do any towing. I used a flip down 80's GM license plate holder and mounted it to flip up. this way will not interfere with hitch and the plate will be visible if stopped by a Cop.
cool68 is offline   Reply With Quote
Old 12-31-2013, 12:07 AM   #10
bigblock73
yeller
bigblock73's Avatar
Here is the mock up of my rear plate. I used a flip bracket to hide yet provide access to my on/off switch. I used 73-87 door bumpers at the bottom to make it close nicely and not rattle.
bigblock73 is offline   Reply With Quote
Old 12-31-2013, 09:15 AM   #11
Claytona08
Claytona08's Avatar
Looks great guys. I would think someone would swap you for a stock bumper Cool68. Bigblock, where did you get your flip bracket?
Old 12-31-2013, 11:26 AM   #12
bnoon
Great idea, except that '82-'92 F-bodies don't have the flip down license plate frame. Those flip downs are mounted on second gen F-bodies which are '70-'81 years. The third gens (TA and 'maro) had a round fuel door on the driver's side.
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 12-31-2013, 11:46 AM   #13
bigblock73
yeller
bigblock73's Avatar
Off a newer caprice, "bubble" bodystyle.
Old 12-31-2013, 11:50 AM   #14
Claytona08
Claytona08's Avatar
Old 01-20-2014, 12:51 AM   #15
midunes
midunes's Avatar
bnoon '82-'92 F-bodies do have the flip down license plate holder hatch lock is behind it.
midunes is offline   Reply With Quote
Old 01-20-2014, 02:05 AM   #16
joe231
joe231's Avatar
I bought a hidden hitch for a 67-72 Chevy from ECE.
It fit very nice on my square CCSB.
There is a write up here that SCOTI did. He had to modify it slightly to clear the factory rivets on the rear most crossmember. My truck didn't have the rivets, I welded the said crossmember in.
http://67-72chevytrucks.com/vboard/s...d.php?t=463666
CHEVY ONLY
Old 01-20-2014, 10:24 AM   #17
Jonboy
Slots go on anything!
The Camaros do. It flips down to access the hatch lock.
1974 Jimmy- 5.3/4L80e/NP241
Old 01-20-2014, 10:43 AM   #18
SCOTI
SCOTI's Avatar
I just swapped another unit under my 89 CC dually. No interference issues w/the frame rivets this time since it's a long wheel base & the rear leafs are now gone.
I did have issues w/the later model 'inside' frame brackets interfering which required a little time w/the grinder to clearance things. After that, it bolted right in.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-20-2014, 05:29 PM   #19
truckfan
truckfan's Avatar
lurk
1981 Chevy C30 440 Holmes 42K one owner miles
truckfan is offline   Reply With Quote
Old 01-20-2014, 07:09 PM   #20
bnoon
You're right! Something I never knew because all of my 3rd gens have been Trans Ams! The TA's have the key hole right in the middle of the taillights and the plate in the bumper with no flip down.
