Old 12-31-2013, 03:15 AM   #1
azratrod
Help me find C50 motor mounts
I need the front puck/doughnut motor mounts for my C50
azratrod is offline   Reply With Quote
Old 12-31-2013, 03:20 AM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Help me find C50 motor mounts
Dino has had several C50's, here is his thread, give him a PM
http://67-72chevytrucks.com/vboard/s...d.php?t=577292
Old 12-31-2013, 03:40 AM   #3
azratrod
Hes my buddy. I sent him a text earlier. He was probably in bed early. He needs all the beauty sleep he can get!
Old 12-31-2013, 10:11 AM   #4
mrolds88
Check Napaonline. I saw several that might fit the bill. They don't have one directly listed for yours. There was what looked like an upper replacement and a lower replacement that I'm sure were listed for something different.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 12-31-2013, 10:46 AM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
You might also try Rockauto the online parts supplier.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-31-2013, 11:11 AM   #6
burnin oil
Look like the standard early motor mounts. You should be able to use the ones for a lighter duty pick up. I know my 60 chevy pick up with a 283 had those. Any supplier for earlier chevys should be able to hook you up. If all else fails hit up a big truck shop. They used bushings like that for mounting auxiliary transmissions. Just be a matter of matching the sleave length. Don't be suprised if they new ones are taller. These things shrink with age, especially when they get oil on them which causes the rubber to break down.
burnin oil is offline   Reply With Quote
Old 12-31-2013, 12:02 PM   #7
mrolds88
Just looked at Rockauto. Check out a 55 Chevy Belair with a 265. Might just be the ticket. Hope you can afford the price.
93 K2500 xcab 6.5TD
Old 12-31-2013, 12:59 PM   #8
burnin oil
$2.90 ouch........ Wonder what shipping is? Might as well do the trans also.
Old 12-31-2013, 01:14 PM   #9
dirtyjim
dirtyjim's Avatar
You might also look into jag v12 mounts,they are usually stronger than your standard puck mount. Last time I bought them they were around $20 each
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies
2004 2500HD utility bed aka Brutus
dirtyjim is offline   Reply With Quote
Old 12-31-2013, 01:34 PM   #10
flashed
Your local NAPA should stock those .
flashed is offline   Reply With Quote
