Old 12-31-2013, 09:50 AM   #1
SCOTI
SCOTI's Avatar
89 CC C30 e-brake cable
Anyone know the trick to disconnecting the e-brack cable on these trucks. My experience w/the pre-75's is a simple bracket/retainer. My dually has some sort of clip/retainer that is not much larger than the cable. It had enough gap to fit an awl in there (I though maybe it pops off) but I felt like I was going to break the awl off trying to do so.
What's the trick before I tear something up?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-01-2014, 01:39 PM   #2
SCOTI
SCOTI's Avatar
Re: 89 CC C30 e-brake cable
Anybody? Does this piece (#5 parking brake cable pic) actually pry off & is re-useable or is it usually destroyed during the removal process?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-01-2014, 02:36 PM   #3
buddy_1
buddy_1's Avatar
I used a pair of channel-locks. You have to catch the pellet on the cable through the slot and squeeze it to the center of the sleeve. Then it will come out through the rectangular opening. Hope this makes sense, Buddy
I know the "VOICES" aren't real but they have some great ideas.
1978 GMC Sierra Classic C25
1983 Datsun 280ZX Turbo
1997 Chevy Cheyenne K2500
1999 Polaris Sport 400
buddy_1 is offline   Reply With Quote
Old 01-01-2014, 03:58 PM   #4
mrolds88
Make sure parking brake pedal is all the way up. Then pull the cable at #5 sideways. This pulls the cable out of the sheath. Put a pair of vise grips on the cable right at the end of the sheath. This will give you room to work. Being careful, use a small screwdriver to lift the little tab that locks the cable end in. Then slide the cable out. I had to do this on one of my trucks when the adjustment nut rusted to the threaded rod.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 01-01-2014, 04:08 PM   #5
SCOTI
SCOTI's Avatar
Ok.... I tried w/an awl but felt like the awl was going to break before the clip came apart from the cable ends. The awls leverage ability is obviously not much (because of it's length/diameter), but something longer/thicker didn't seem to fit.
I guess I'll spray everything down & try again now that I know the clips are available.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-01-2014, 04:31 PM   #6
mrolds88
Worse comes to worse, Rockauto has them for less than $2 each.
93 K2500 xcab 6.5TD
Old 01-01-2014, 05:29 PM   #7
SCOTI
SCOTI's Avatar
That was my next place to look. Went by OReillys & they gave me that weird look. I know part of the problem was I don't know the correct GM term for that clip (I was explaining to them I needed an e-brake cable retaining clip so they were telling me they're in the HELP section).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
