Old 12-31-2013, 12:14 PM   #1
jasonda
4wd 4sp trans tunnel
I need some help from you knowledgeable people about a trans tunnel. I have a 68 auto on the column cab that I am placing on a 4wd 4spd manual chassis. I was able to locate a local 70 model 3/4 ton 2wd manual trans cab and chassis that had a good tunnel in it but I am not sure if this is the same tunnel as would be in a 4wd manual truck. Can someone help me and let me know if this is the correct tunnel or do I need to find one specifically out of a 4wd manual truck. Thanks
jasonda is offline   Reply With Quote
Old 12-31-2013, 12:30 PM   #2
54blackhornet
54blackhornet's Avatar
Re: 4wd 4sp trans tunnel
It should bolt in , I have a 2wd C-20 and a 71 K-10 both high hump floor cabs. They interchange except for Extra hole for TC
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 12-31-2013, 02:17 PM   #3
hugger6933
The high humps will all be same the difference is just the holes for what ever shifter is in the truck. Jim
hugger6933 is offline   Reply With Quote
Old 12-31-2013, 05:09 PM   #4
jasonda
Thanks for the info
