Glowing since 1978
How do you get the headlight switch knob off?
I know this was posted many times and of course I didn't commit it to memory. Search is down so I'm going to need someone to share their wisdom with me. In addition to this question, can the dash bezel piece be replaced without puling the whole gage assembly out? It looks to me like the front screws can be removed from the bezel and then the attaching screws on the back can be removed allowing just the bezel to come out. Any input would be appreciated. I did manage to get the windshield wiper knob of and the nut removed so the only thing stopping me now is the headlight knob. Thanks, Don
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
Formerly yellow72custom
Reach up underneath the dash, and feel for the headlight switch directly behind the headlight knob. On top, you will feel a little spring-loaded button. Push down on the button, and wiggle and pull out the headlight know. Should come right out
![]() Pulling the dash is so easy, i would go ahead and pull it to put on the new bezel. Just disconnect the oil pressure line, wiring harness (directly behind the gas guage), and speedometer cable, then unscrew it and pull it out. Good luck!
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
67-72 truck surgeon
I usually just yanked that knob and rod right out, I didn't even know about that release button. I like your way better.
1969 Chevy C10 1993 Toyota Camry LE 1999 Ford F250 Super Duty 4x4 diesel 2008 Dodge Charger Super Bee 1953 International R182 |
newly minted old timer
pull it out all the way first!!!! then hit the button.. youll drive yourself nuts the other way
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
huh?
![]() Join Date: May 2000
yeah, what dave said
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
Glowing since 1978
Thanks to all for your assistance. Thank you yellow72custom. I decided to pull the whole thing and it went very smoothly. It's all back together now and look real nice.
