![]() Join Date: Jan 2012
Parts Lot
Trying to clean out the garage and get rid of some items taken off my truck in the last 12 months along with some items that I bought but did not use. Most prices include shipping.
Holley 750cfm vacuum secondary carb - 3310-4 (could probably use rebuild) - $60 sold Summit Racing adjustable fuel line w/gauge - SUM-G3120-1 (installed but used less than 1 hr.) - $30 sold Dual feed fuel lines (used) - $15 ARP valve cover bolt kit - 100-7503 (new) - $8 Summit Racing fuel hose fittings - SUM-3116 (new) - probably not worth the cost to ship separately, but if you buy something else and want them, I'll include for $2 Chrome valve cover T-bar hold downs (used) - $12 Carter mechanical fuel pump - M4685 (new, never installed) - $17 Edelbrock Fuel Pump - EDL-1721 (used) - $30 sold 67-68 Instrument panel w/o gauges (worked fine when removed 30 days ago) - $25 Arm rests (appear to be red but dyed black, one is broken… see pic) - $10 plus shipping Aftermarket seat belts (black), 2 retractors and 1 center belt (used, dated 2002, the hold down tab on one of the plastic retractor covers is broken…see pic) - $30 sold 9" diameter air cleaner - $7 plus shipping Last edited by tx68; 01-13-2014 at 11:04 PM. Reason: add prices, update sold parts |
Re: Parts Lot
More Pics
Re: Parts Lot
More Pics 2
Re: Parts Lot
Hello
How much for the seat belts with shipping to 28409 Thanks Bill |
Re: Parts Lot
If I split up, I'd probably do $30 shipped on the seat belts.
![]() Join Date: Aug 2012
Re: Parts Lot
how much for the edelbrock fuel pump to 34446
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper |
Re: Parts Lot
if Ontrak passes on the seatbelts, I'm interested.
thanks Paul
Houston Area Lawman 72 GMC Fleetside (AKA: MERLIN) ZZ4 Crate Engine TH400 with Stage two kit |
Re: Parts Lot
I'll take the seatbelts send me your payment info
Thanks Bill |
Re: Parts Lot
How much for the fuel gauge? And shipping to 83634?
Re: Parts Lot
How much for the Summit Racing adjustable fuel line w/gauge - SUM-G3120-1 shipped to 51503. Will it fit a holley carb. If so Ill take it if you have a fair price. Unless its the same thing low&slow is asking about. Then I will get in line.
Re: Parts Lot
Yup get in line. Same part I'm asking about,
Re: Parts Lot
Given the interest in the a few of the items individually, I'll go ahead and split up. I'll put prices in the original post.
Ontrak12 - The seat belts are yours. gdavis - $30 shipped for the Edelbrock fuel pump (note: I bought this used at a swap meet last year but never installed it, so I can't guarantee it works. Also, there is a newer version of the 1721 that has been out for a couple years. This is the older version. They look a little different.) low&slow - $30 shipped on the summit racing fuel line w/gauge. ecgate - Yes, this will fit a Holley. I installed it on the one that I am selling in this post but ended up switching carbs to one with only a single feed. |
#13 |
Re: Parts Lot
I understand about swap meets so i better back off of it but thanks for being truthful and God Bless
#14 |
Re: Parts Lot
How much for the arm rests shipped to 89014..
#15 |
86 Scottsdale
Re: Parts Lot
I'll do $30 shipped on the Eddy fuel pump.
#16 |
Re: Parts Lot
carb is manual choke single pumper correct? interested. i will run the numbers to see if any of mine are comparable as i need some parts.
#17 |
Re: Parts Lot
I'll pass on the fuel pressure gauge. ecgate is next in line on that part.
#18 |
Re: Parts Lot
Ill take the Summit Racing adjustable fuel line w/gauge for $30 shipped. PM sent.
#19 |
Re: Parts Lot
crawley - since 1 of the holes on 1 arm rest is busted, and there is some wear on both, I'd do $15 shipped.
frednoah - the Edelbrock fuel pump is yours, just want to make sure you saw my above comments to gdavis. ecgate - the fuel line w/gauge is yours. |
#20 |
Re: Parts Lot
rich67 - it is manual choke, it does have dual fuel inlets, but it is a vacuum secondary rather than mechanical secondary (aka double pumper?).
#21 |
86 Scottsdale
Re: Parts Lot
Yeah I saw it. Figured it's worth a shot. PM me how you'd like to be paid.
#22 |
Re: Parts Lot
What will It take to shipped to N.C. 27360 on the Holley 750.Thanks Randy
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15. Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e, ![]() |
#23 |
Re: Parts Lot
RCbowtie69 - the price of $60 for the Holley carb includes shipping
#24 |
Re: Parts Lot
Then i'll take it.Will MO work for you also?Thanks Randy
#25 |
Re: Parts Lot
double pumper means it has two accelerator pumps. and i guess i didnt get an "ill take it" out soon enuff. my bad. but i do want it if it doesnt work out cause its the right one after checking numbers. thanx, rich
