12-31-2013, 08:10 PM | #1 |
How to get headlights brighter?
My green 1970's headlights aren't terribly bright (old truck, I know). However, it seems like even other older pickups have brighter lights than mine. The green '70 is my daily driver when I'm at college, so I need it to be a little bit more safe. Most of the time I just drive at night with the high beams on all the time because they are almost as bright as a modern vehicle's low beams.
Are there upgraded headlights that I can buy? I've thought about the HID lights that LMC offer, but those cost an arm and a leg. I like the look of those blue lights on some modern cars, and seeing as how one of my Christmas presents was a set of LED taillight bulbs so my brake lights will be brighter, I figure I should get brighter headlights as well. As always, any ideas and suggestions would be appreciated. Thanks!
White70C20 1970 Blue C20 - 250, 4 speed 1985 Ford Thunderbird 2005 Pontiac G6 |
12-31-2013, 08:23 PM | #2 |
Re: How to get headlights brighter?
you can easily take a half hour or so and disconnect all the wire teminals and clean them up to bright and shiny metal to metal contact and have brighter lights for free
12-31-2013, 09:01 PM | #3 |
12-31-2013, 09:10 PM | #4 |
laying low
Especially clean the ground wires. And I believe there is the topic up in the faq section on brighter headlights.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
12-31-2013, 09:25 PM | #5 |
Watch out for your cornhole !
After doing the basics (mentioned above) as far as cleaning the wiring on what you have, you can do the relay mod. Its free to cheap, doesn't take long, and will help a ton.
Cliff notes, with all your wiring in tip top shape and the relay mod with inexpensive over the counter Halogen bulbs, you'll be happy.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 01-01-2014 at 07:37 AM. |
12-31-2013, 10:40 PM | #6 |
I swaped my bulbs to the headlight housings out of a 2008 jeep wrangler they use an h13 headlight blub which i will be doing a relay mod so i dont burn out the headlight switch
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
12-31-2013, 10:44 PM | #7 |
20' Daredevil (Ret)
Ditto everything posted above, and I'll add this: no blue bulbs!!!!! Even if you don't care about the glare blinding oncoming drivers, they will absolutely kill your ability to see at night. I learned this the hard way several years ago, and more recently I learned something about the science behind it.
Some HIDs have a slightly bluish tint, but that's a whole other matter.
12-31-2013, 11:22 PM | #8 |
Moderator
Relay mod and Sylvania silver stars...you will be very happy.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
12-31-2013, 11:39 PM | #9 |
12-31-2013, 11:42 PM | #10 |
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
12-31-2013, 11:57 PM | #11 |
Thanks guys!
What exactly is the relay mod? Does it take very long?
01-01-2014, 12:00 AM | #12 | |
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
01-01-2014, 12:57 AM | #13 |
Some manufacturers tint the bulbs blue to make the lights look brighter.. however the light output is very low. People still buy them like hotcakes cause they see it as a cheap alternative to hids.
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
01-01-2014, 01:32 AM | #14 |
Quit if it's not FUN!!!
http://www.rallylights.com/h6024-7-r...dlamp-kit.html
Opt for the 100/55W hi-beams and don't look back. Definitely add the relays, though |
01-01-2014, 01:36 AM | #15 |
You can do hids lo/hi beams and housings for less than a $100
01-01-2014, 01:48 AM | #16 |
Msgt USAF Ret
Here's the relay mod from the electrical FAQS in the electrical forum.
.......http://67-72chevytrucks.com/vboard/s...d.php?t=188478 with our own TX Firefighter.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-01-2014, 06:15 AM | #17 |
Where would you suggest I go to get that stuff? At under $100, is it quality stuff?
01-01-2014, 07:45 AM | #18 |
I'll give you some advice from a old man to a young man.
Don't spend a single cent on aftermarket headlight improvements until you have addressed making sure your current headlights are as good as they can be by following Cdowns suggestion. Only then, if you're still not happy, do the relay mod. That mod addresses poor design that these trucks had from the factory. And then, if after you've tuned up your wiring and done the relay mod, should you consider spending coin on HID or whatever. I say whatever when referring to HID stuff because I have built a crap ton of these trucks, and with good wiring and relays, never felt the need to spend any more to try and improve them, so I don't even know about HID stuff. And, I'm the guy who drives down desolate roads at 4 AM through deer country on my way to work for the last 20 years.
01-01-2014, 08:55 AM | #19 |
Hids that most people run as far as brand
http://m.ebay.com/itm/330568751529 Conversion housings I purchased because they are glass http://m.ebay.com/itm/380693270834 |
01-01-2014, 10:57 AM | #20 |
Old member
I have done the relay mod and I added the lights with replaceable bulbs. As far as what they are I have know idea but they are bright. Getting the factory wiring woking properly is the first thing you need to do though. My headlights are twice as bright as the factory lights I would say.
I bought the lights at the Myrtle Beach car show several years ago.
01-01-2014, 02:47 PM | #21 |
I agree with everyone else: check your wiring first. Years ago I bought a 72 Cheyene and the headlights were weak. I noticed that a PO had cut the ends of the headlight connecters off and had just wrapped the end of the wires onto the headlight tangs. I replaced the front wiring harness and had bright, consistant headlights again.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. |
01-01-2014, 05:54 PM | #22 | |
01-01-2014, 06:11 PM | #23 |
here is your answer , read all of it
http://madelectrical.com/electrical-tech.shtml
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
01-01-2014, 06:13 PM | #24 |
01-01-2014, 06:26 PM | #25 | |
