Old 07-17-2003, 08:14 PM   #1
Project1970
14.1 @ 96MPH
Project1970's Avatar
Talking My A/C is back!!!
Fiiiiinally.
It wasn't hard, just took a while seeing as I didn't have a proper wire crimper handy, and no electricity to fire up the soldering iron...now all that's left, really, is to head up to Phoenix, and use my dad's tools to properly secure the relays and switch with some brackets. (That, and a new set of brale pads.)
I've never had the fan work on high...let alone high with fresh wiring! The amount of air it puts out is awesome...but I may need to look into a bigger alternator, as just the fan alone - no A/C compressor - is enough to drop the idle a bit!
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 07-17-2003, 08:22 PM   #2
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
If you ever figure out what the problem is please let me know please. I have yet to find what would cause the problem
67Fleetsidedream is offline   Reply With Quote
Old 07-17-2003, 08:32 PM   #3
Project1970
14.1 @ 96MPH
I should rephrase that, I suppose; now it works on high, it never has before. It wasn't really due to a failure, but more as a precaution - it got the feed wire HOT in about 10 seconds!!!
No pics, but here's how I have it set up:
*12V from the post on the fender running through 30A fuses to the 30 post on the 30amp relays
*12V, tapped from the "lighter socket" feed (newer wiring, I installed it a few years ago) to the center contacts of a DPDT switch
*Two of the remaining contacts on the switch (one on each end) to 85 on the fan relay
*One contact on the switch to 85 on the compressor relay (so center is off, left is A/C, right is just fan)
*86 on both relays to ground on firewall
*87 on fan relay to fan power wire
*87 on compressor relay to compressor power wire
It's quite simple when you get down to it...
Edit: It's also now ALL 12 gauge wire, even the low-current switched side.
