Old 12-31-2013, 10:29 PM   #1
Chevy Fleetside
Chevy Fleetside's Avatar
Gas Tank
I am thinking about this gas tank for the trucks. Seems to be a solution for not being able to pay over $400 for an aluminum tank. Seems to be the perfect size also.. https://www.streetrodhq.com/detail/1...Bed_Mount.html
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 12-31-2013, 11:11 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: Gas Tank
John I used one from Bob Drake for `49 to `52 chevy, tanks with sender delivered for $170. You can also get it at Tanks Inc, both are 18 gallon, the one from Drake has a drain fitting in the bottom.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-01-2014, 01:03 PM   #3
TJ's Chevy
TJ's Chevy's Avatar
Re: Gas Tank
I think Classic Parts and LMC sell rear mount frame tanks. Believe they are 20 gallon tanks.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 01-01-2014, 03:40 PM   #4
Rich 5150 69
Re: Gas Tank
John several reasons I went with the tank I did was to maximum the size without dropping below the bumper line, plus its already setup for F.I. if I decide so later on, drain plug, and a smaller filler tube 1 3/8 vs 2 inch which allow me to run it thru the frame as opposed to over it and does not interfer with the bed sills, it all sits level with the top of the frame rails....pic below at 20 ft back 10 inches off the ground.
Old 01-01-2014, 10:26 PM   #5
Chevy Fleetside
Re: Gas Tank
I have the 20 gal tank in my blue truck and it is just to big, or I should say to tall. I have to cut the cross sills really thin. They just don't work properly with our trucks. I might go with the 49 to 52 tank but still not sure.
Old 01-02-2014, 12:28 PM   #6
kieth
kieth's Avatar
Re: Gas Tank
WE actually cut one rear bed crossmember off, added a 1" piece of channel to maintain the proper length, then added 2 support brackets whick bolted to the frame and then supported the cut bed crossmember. No structural problems to date. (14,000 miles) here is a link to the build and the mods, just click on the right hand arrow to keep advancing the pictures for all the mods we did to make it work.
http://kieth.smugmug.com/Trucks/66-GMC/i-DrSmCmf/A
kieth is offline   Reply With Quote
Old 01-04-2014, 07:46 AM   #7
mark 66
Re: Gas Tank
do you need a electric pump when you move tank out back?
mark 66 is offline   Reply With Quote
Old 01-04-2014, 12:01 PM   #8
Chevy Fleetside
Re: Gas Tank
No Mark66 as long as you don't have fuel inj.
