Old 12-31-2013, 11:29 PM   #1
rs74
rs74's Avatar
K30 rear spring question.
If I take the overload springs out will I have to worry about the rear of the truck dropping any. With these springs in there it rides way to rough. It's like it has a solid suspension. I took a 9" torpedo level and put it on the bed rail and it has about 3/16-1/4" of rake from rear to front. So it could use a little drop in the rear to level it out a bit. I am going to have to measure to see what length of new U-bolts I will need to replace the old ones.
Not good pics but here they are.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 01-01-2014, 08:07 AM   #2
mrolds88
Re: K30 rear spring question.
First thing I would try would be to take the cross bolt out of the lower "helper" spring. The one I'm referring to is out on the end where there are 3 or 4 holes on the bracket. That may be where you are getting some of your problem. The upper helpers shouldnt play a part in the ride until you get some weight on. I think I would look at the upper helpers though, they look like they may need some attention, unless it's the camera playing tricks. If the lower helper thing works, I think if you pull it and put new u bolts that should drop you about where you want.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
