01-01-2014, 01:35 PM | #1 |
i need throttle cable suggestions
i have a '69 gmc 4x4 4spd, putting in '71 402, and its a '71 cab/peddle. what would be a correct fitment for a throttle cable? i have one which is 18'' (6264974) i believe. thanx, paul
01-01-2014, 02:51 PM | #2 |
Re: i need throttle cable suggestions
It should be the same cable for a SB or BB in a 4x4. I would keep the linkage rod setup personally. I think that it fits better than the factory cable which is to long and ends up with a S shape between the cab and carb bracket. Mine just broke and I ended up buying a Lokar replacement for it.
01-01-2014, 03:05 PM | #3 |
i have the 69 setup someplace??? lol
01-01-2014, 03:06 PM | #4 |
I couldn't
get my cable style to bolt to the firewall. Had to uses the original rod assembly. Is this normal? 3 bolts to the firewall on the inside wouldn't work.
1969 GMC 4x4, 4 speed, 350 Fleet Side in progress. 1969 Camaro SS 427 Cortez Silver. owner since 1974 1964 Chevelle 4 Door, 427 Big block,Turbo 400 1/4 Mile 10.52 @ 125.85 mph. 1.39.1 60' 1982 Crew Cab 3+3, 2WD 3.21 Locker, 468/4 speed 1969 C30 4 speed (IL6) future build. |
01-01-2014, 04:43 PM | #5 |
You must be talking about the gas pedal. The cable just passes through the firewall. I have never swapped one over but it has been done alot. GM even did retro fits so it cant be that hard. A little searching on here should resolve your issue.
01-02-2014, 01:57 PM | #6 |
Thanks, I will keep looking.
01-03-2014, 07:39 PM | #7 |
I don't know if this will help as I didn't do a cable. I used the stock pedal mount and made a piece of linkage out of some aluminum rod, 2 Heims joints, plastic washers and a couple of bolts. It cost me about $10 from Ace Hardware.
PS I gave it a bath since then too.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
01-05-2014, 08:04 AM | #8 |
nice setup
