Old 07-17-2003, 09:12 PM   #1
72bigblock
hauling a cab
what is the best way to haul a cab in a 02 chevy short bed?? thanks chris
72bigblock is offline   Reply With Quote
Old 07-17-2003, 09:16 PM   #2
Alexis
Member since 2000
Alexis's Avatar
most guys just put the cad side ways in the bed. it fits perfect. maybe it will do the same in your 02.
Alexis is offline   Reply With Quote
Old 07-17-2003, 09:23 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
What Alexis said or...
You might be able to get away with lying the cab on its back, and putting it between the wheelwells. The beds on late model P/U's are pretty big, so it might work. Either way, make sure you tie it down really good, then drive off
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 07-17-2003, 09:33 PM   #4
72bigblock
also thanks chriswhy do i need a high hump cab for a big block and thm 400?
Old 07-17-2003, 09:35 PM   #5
Alexis
Member since 2000
Alexis's Avatar
cause on a low lump there is a lip that nags down that you have to bend inward to fit in that transmission. The high humps allows for room. I think that how it go's.
Old 07-17-2003, 10:14 PM   #6
Class of 69
Class of 69's Avatar
The cab will fit in the bed sideways, BUT it will sit in the wheel housing on the back of the cab!! I had to use 4 tires on rims as spacers to keep the cab above the wheel housings!!
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 07-18-2003, 10:19 AM   #7
72bigblock
ttt
Old 07-18-2003, 08:40 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Good idea on putting tires down there...mine did get damaged a little.
