01-01-2014, 02:53 PM | #1 |
I'm trying....
Utility bucket to Sport bucket conversion
There are several threads about conversion from a bench to buckets in trucks, but I have found few specifics with regard to conversion from Utility Buckets to Sport Buckets in Blazers. Because there are obvious differences in the seat mounts and mounting points, I would assume there would be underfloor support differences. Is it correct to assume that one would follow the same sequence as a bench conversion and need to come up with the same under floor reinforcements?
Can anyone comment on this? Thanks Brad |
01-01-2014, 11:15 PM | #2 |
Carpe manana
Re: Utility bucket to Sport bucket conversion
Curious myself. I figured the bracket mounts would be the same but maybe I'm wrong. Anyone know?
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
01-02-2014, 04:43 PM | #3 |
The front holes are the same of Utility vs Sport. The rear mounts of the utility seats are further back. When I put the utility seats in my 72 it already had the mounts on the bottom for both styles all I had to do was drill new holes through the floor pan that lined up with the extra mounts.
70 Chevelle SS (clone), 454, 350 auto 71 K5 350, 350 auto, 3" body lift, 35's -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |____|__|___] *.*..*.*.._@_ _ _ _ @ |
01-02-2014, 06:09 PM | #4 |
I'm trying....
Thanks lopemaxx. That is encouraging…though there seem to be a lot of stories about differing floor pan scenarios in trucks…some having dimples and some not. I'll find out soon enough. I wanted to get in line for RogerKoop's brackets while they lasted on the parts board if the likelihood was that I needed them.
http://67-72chevytrucks.com/vboard/s...d.php?t=557195 …but I'll just wait and take my lumps when the body comes off in the next month based on your experience. |
01-02-2014, 09:08 PM | #5 |
I did this about 8 years ago on a 71 I had. Basically made it a CST with trim and all. It wasn't hard to adapt all the parts and it looked pretty good.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
01-02-2014, 09:15 PM | #6 |
I'm trying....
Did you find all the support bracketry you needed already in place under floor? What you did is exactly what I plan to do... Go from base to CST.
01-03-2014, 12:27 PM | #7 |
No if I remember right only the front holes fit and I had to re drill the rear as lopemaxx mentioned. I just drilled new holes and used some thick gauge metal as a large washer for support. No one would know with carpet down and unless they climb underneath you can't see the new holes.
02-14-2015, 09:21 PM | #8 |
Brad, I know this is an old thread, but I was wondering how your sport bucket conversion went. I am getting ready to tackle this myself on my Blazer and was just wondering if you had any helpful tidbits of info on the subject.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
02-14-2015, 10:31 PM | #9 |
I'm trying....
Nothing special...when you get into it, it'll be self explanatory. I did not have duplicate bracketry like some report...only what was needed for the original utilities. I'm sure you've seen Roger Koop usually has bucket brackets for sale. We just made our own, there's not much to them. We started with the outside front hole on both sides, and that seemed to give us the right positioning. We mocked up the console at the same time...and even pulled a center line to check alignment. All the other holes had to be drilled and existing holes filled.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
10-04-2019, 12:21 PM | #10 |
Bit of an old thread, but does anyone have a bit more info on this subject? Can the brackets from the Utility seats be configured to work with the sport seats, or are they completely different?
1969 K5 Blazer - 507 Light Blue - http://67-72chevytrucks.com/vboard/s...d.php?t=802858 |
10-04-2019, 01:26 PM | #11 | |
I'm trying....
I see people on this board do amazing things everyday...so the question of whether utility bucket mounting brackets can be configured to fit sport buckets is probably moot, if you want to make something work bad enough--you probably can. If you want sport buckets, but don't have the correct Blazer mounting brackets for them...my advice would be to follow the classifieds closely as they often come up for sale. Best of luck regardless of whether you're looking for parts or making parts (or both).
10-04-2019, 08:48 PM | #12 |
Well, they are not completely different, that is the brackets, but the angles are set at a different height. My truck is not in my shop right now, or else I could give you demensions.
But, the most obvious difference is the lenght of the seat bracket. I'm sure you could drill out the rivets, and massage them to work, but I have not done it As iron canine says the brackets can be had, but they seem to be very pricey these days
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
10-05-2019, 08:19 AM | #13 |
Here is a picture of the plate that the catch bolts to on the passenger side. This was a sport bucket blazer but you can see provisions farther back for the utility buckets. Holes but no square nuts attached. The drivers side is a different animal as IronCanine has mentioned some have come with both I've included some pictures with dimensions but I have only personally seen 2 and heard of 2 more.
