Carpe manana
![]() ![]() Join Date: Dec 2010
Aluminum Dana 60 diff cover
New was sold to me by mistake as a Dana 44 cover but is a Dana 60 cover. This is not but resembles the vintage finned Hickey 12 bolt/Dana 44 diff covers and has more of a cast rather than polished finish. How's $65 shipped? I could use a similar appearing Dana 44 cover.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Re: Aluminum Dana 60 diff cover
will that fit a front dana 60 86 model???
4x4k30 if trouble was money i would have plenty |
Carpe manana
Great question - I don't know. Any idea how to tell?
it looks like they are the same here is a pic i found of a front..... how thick is the one you have ?
4x4k30 if trouble was money i would have plenty Last edited by 4x4k30; 01-02-2014 at 09:18 AM. |
put me in line.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#6 | |
Carpe manana
Gotcha in line.
next in line can have it thanks
it will fit any dana 60. cover pattern didnt change. it will even fit dana 70s.
Carpe manana
jjzepplin you're up.....the metal is ~3/16" thick or slightly greater
How tall is it If you lay it down on the flat side (mounting side)?
Carpe manana
From the ground up it's about 4.5" at the tallest fin....
OK I just want to make sure it will clear the stabilizer I have. Will measure tomorrow. But looks good so far.
#13 |
Carpe manana
Sounds good, thanks...
#14 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Next in line if it gets this far......
#15 |
Looks like it will hit my stabilizer. Gonna pass DARNIT! Would have looked good on the front of my rig too.
#16 |
Carpe manana
You're up Captainfab...
No worries, thanks.
#17 |
A Dana60 housing is a Dana60 housing. The question is,will the tie rod & stabilizer clear. I've run finned aluminum front covers in the past and as I recall the fins were clearanced for the tie rod. One purpose of these covers was generally increased capacity,which sometimes meant standing off the mating surface farther. Rear no problem (w/leaf). Rear coil or front,better measure/check. It's possible if it's too tall that the fins could be clearanced. I'd get in line but a day late on the draw
