Old 01-01-2014, 05:39 PM   #1
shortbed70
shortbed70's Avatar
Sway bars and bags?
How are you guys mounting your swaybars with bags? My control arm mounts are welded on but problem lies when laid out I bent the bolt that holds the bushings from to much angle? Is there a high angle link kit for a sway bar? For a 65 Chevy c10
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 01-01-2014, 11:40 PM   #2
chevyrestoguy
chevyrestoguy's Avatar
Re: Sway bars and bags?
Don't use the factory thru-bolt and bushing set-up on the lower control arm. Weld some tabs on the lower control arm and use a heim joint that can articulate. Or, you might be able to find a clevis with a threaded end and bolt it to the lower control arm, and then use a heim joint. What type of end do you have on your swaybar? If you have a sway bar with an eyelet on the ends, then use the bolt and bushing set-up on that end, and find a female heim that will thread on to the end of the bolt.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 01-01-2014, 11:47 PM   #3
chevjayfsd
Project 7dos
chevjayfsd's Avatar
We just got done with our bag install, and took the sway bar off... It's amazing the difference between a static drop with a sway bar, and a bagged setup with no sway bar.... This thing rides on rails now...
Have you tried without the sway bar?
7DOS - 1972 C-10
350/350
Porterbuilt/Accuair
20x8.5/20x10
Ride Low or Die
PSSST - Yes it's bagged.
7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290
chevjayfsd is offline   Reply With Quote
Old 01-01-2014, 11:57 PM   #4
shortbed70
shortbed70's Avatar
Eyelet on bar end and using the l bracket that came with the addco bar kit.
Yea ran it all year without it and if you look at my build I put the valves as close to the bags as possible and still want more stability..
Troy
Big Red Dog build
Old 01-07-2014, 09:12 AM   #5
shortbed70
shortbed70's Avatar
Think I got it figured out... Late 90's early 2000 Chevys ran a sway bar link that looks like it will work so I'm going to see what I can fab up..
Troy
Big Red Dog build
Old 01-07-2014, 12:14 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Huh? I have found it to be just tho opposite. Adding a sway bar to a bagged truck is a HUGE improvement. You might try putting it back on and test it again.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-07-2014, 01:36 PM   #7
shortbed70
shortbed70's Avatar
That's kinda what I thought... I did an install on a cutlass and ended up putting the sway bar back on! My truck I want to handle cornering like autocross cars!
Troy
Big Red Dog build
Old 01-08-2014, 12:05 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
I have "heard" from others, but I can personally attest to my experience. My 77 Cheyenne did not have a sway bar from the factory. Its was bagged and driven for a full season without one. The next season I found a 1 1/8" bar from a C/20 and installed it with the clamps bolted directly to the frame. There was a very noticeable improvement in stability and a lot less lean in the corners.
I "always" recommend a sway bar with bags.
Articles-
"Refining Sierra"
Old 01-08-2014, 12:22 PM   #9
SCOTI
SCOTI's Avatar
I would always recommend a sway bar regardless of spring choice up front.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-07-2015, 07:09 PM   #10
epon
epon's Avatar
wondering if OP got theirs setup and if so do you have any pics?
'82 C-10 SWB / C'd, Z'd, Body'd and Bagged / Shaved firewall, wiper cowl, drip rails, stake holes and tailgate/ 20" & 22" Milanni Voodoo
'81 C-10 SWB Parts Truck
IRC - http://webchat.snoonet.org/#baggedtrucks
epon is offline   Reply With Quote
Old 02-09-2016, 11:47 AM   #11
northeimcustom
northeimcustom's Avatar
anyone have to cut sway bar ends shorter when running with bags???
*^MY BUILD STORY^*
northeimcustom is offline   Reply With Quote
Old 02-09-2016, 10:25 PM   #12
3drburb
Yes, I did and I bet a lot of others here had to do the same.
3drburb is offline   Reply With Quote
Old 02-09-2016, 11:59 PM   #13
northeimcustom
OK, I have a 1&1\4" or so sway bar I'm mounting on my 83 c10 with bags, plates and cups and drop spindles. I plan on bolting just the 'strap' bands on the bushings directly to the frame and stock LCAs. There is one hole about 2" off more towards the bumper on each side of the frame. No other holes or rivets near where the mount lines up.... Should I have the truck aired out and the sway bar back ends as close as safely possible to the empty bags? Then mount sway bar frame brackets aired out so it draws away from bags going up?? Or does the sway bar even move when clamped up?? What do you think???
*^MY BUILD STORY^*
Old 02-11-2016, 11:14 AM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
I would set it at ride height and install it from there. You want your end links to be perpendicular at ride height, which means they will be canted when aired out.
Articles-
"Refining Sierra"
Old 02-16-2016, 09:30 PM   #15
northeimcustom
*^MY BUILD STORY^*
