Old 01-01-2014, 07:04 PM   #1
DGulliver
DGulliver's Avatar
Help with power steering brackets
Hello all, I'm trying to install power steering on the 72 stepside. It's a V8/TH350 auto. I pulled the steering box and pump from a working '71 C/10.
My problem is I have a later model V8, maybe 80's or 90's? and am going to need a different bracket to mount the pump. Can anyone tell me what bracket/year range I'm looking for? Thanks for any help!
'72 Chevrolet Step Side 350/TH350, '63 C10 Step V8
'74 Trans Am 400, '80 Trans Am Indy Pace Car
Mercedes AMG S55, SLK230 Kompressor, GL450
'96 Dodge Indy Ram Official Indy Truck
'99 Porsche 911 Carrera
DGulliver is offline   Reply With Quote
Old 01-01-2014, 08:07 PM   #2
asolde
asolde's Avatar
Re: Help with power steering brackets
There is a correct set of brackets for sale on the parts board for $50
http://67-72chevytrucks.com/vboard/s...d.php?t=610222
1972 cheverolet K5 CST Blazer
350/auto/AC/PS/PB/Aux Batt
From Medford, Oregon
asolde is offline   Reply With Quote
Old 01-01-2014, 08:58 PM   #3
DGulliver
DGulliver's Avatar
Thanks for that asolde. Those look like the correct '72 brackets, but they won't work on my later model engine. I think I need something from the 80's or 90's and am wondering if someone else has run into this.
Old 01-01-2014, 10:37 PM   #4
BigRed76
BigRed76's Avatar
Those power steering pump brackets will work on your engine, but you're missing a little bracket that bolts to the outer corner of the left cylinder head, using the front header bolt.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 01-01-2014, 10:44 PM   #5
BigRed76
BigRed76's Avatar
The bracket you need is like the one circled in the picture...
Zach
Old 01-02-2014, 04:51 PM   #6
DGulliver
DGulliver's Avatar
Thanks, Zach! What should I be asking for, since I need to buy one?
Old 01-02-2014, 06:58 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Bigred is correct. Those are the ones you need.
On your pump, the bolt hole right up by the filler cap lines up with the threaded hole in the front of your cylinder head. You'll need some sort of little spacer (stack of washers works) since you don't have air conditioning bracket behind the power steering bracket.
The long slotted ear on the side of the pump lines up with the threaded hole in your water pump.
Pretty much any GM small block car or truck from the mid 70s up through serpentine equipped vehicles can supply the missing little bracket that goes on the back.
Old 01-02-2014, 07:40 PM   #8
ray_mcavoy
Actually, there were two different designs of pre-serpentine long water pump power steering brackets.
The first style was used up until 1976 and uses a "cradle" bracket that bolts through an un-threaded mounting boss on the water pump.
The second design was used from 1977 & up. This one has the bracket bolted to the front of the PS pump and it bolts into a threaded boss on the water pump.
As far as I know, the various brackets & parts are not interchangeable between the two styles. And they have to be used with the corresponding design of long water pump in order to line up correctly.
DGulliver, From what I can see in your pics, it looks like you have the 77-up bracket for the front of the pump and are missing the outer support as Tx Firefighter pointed out. However, it also looks like you might have the 76 & older style water pump with the un-threaded mounting boss.
ray_mcavoy is offline   Reply With Quote
Old 01-02-2014, 08:17 PM   #9
Bigdav160
Bigdav160's Avatar
That's a long water pump in the first photo.
I don't think the short water pump brackets work.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 01-02-2014, 08:26 PM   #10
ray_mcavoy
I know. Both of those diagrams I posted are for long water pumps.
I agree ... he needs to use brackets meant for a long water pump. But as I posted, there are two different styles of brackets for long water pumps and the parts between those don't interchange either.
Old 01-03-2014, 09:52 AM   #11
kelbystanley
I have a set im not using but they are for a short water pump.
kelbystanley is offline   Reply With Quote
Old 01-04-2014, 09:46 PM   #12
DGulliver
DGulliver's Avatar
Thanks everyone for the generous and knowledgable input! Now to round up some pieces..
Old 01-05-2014, 08:45 AM   #13
kelbystanley
http://www.ebay.com/itm/SBC-POWER-ST...83334b&vxp=mtr
Try this one. it's the one im using.
