Old 01-01-2014, 08:03 PM   #1
Ackattack
Ackattack's Avatar
Idle problem on a 94 tbi
So driving around, my truck has developed an idle problem when I come to a stop. It will stumble real bad (sometimes) and has died a few times. Other than that it drives fine.
So I started checking stuff and took out the IAC to clean it. When I put it back in, I over tightened it, so I removed the TBI assembly and got the IAC out. Cleaned up the TBI assembly and reinstalled with a new gasket and new IAC. No change in the idle.
Then today I started messing with it again. I had it in park and stepped on the brake and the idle sped up and then dropped back down. So my suspicion is a problem with with the brake booster or check valve.
Before I go replace the brake booster, I wanted some input from others.
Ackattack is offline   Reply With Quote
Old 01-02-2014, 12:15 PM   #2
Re: Idle problem on a 94 tbi
I agree with you, but honestly don't know any other checks other than plugging the manifold where the booster is connected to see if it goes away there.
Old 01-02-2014, 02:26 PM   #3
sntrym95
sntrym95's Avatar
Could also be the MAP sensor or EGR valve but most likely a vacuum leak - either in the brake booster or on the manifold/TBI.
Mike
sntrym95 is offline   Reply With Quote
Old 01-02-2014, 02:55 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Stumbling idle and dying at idle also points to EGR valve sticking slightly open.
Old 01-02-2014, 11:26 PM   #5
mgchevyparts
mgchevyparts's Avatar
Bad booster will be a vacuum leak when you depress pedal, eliminate booster and see if it runs fine.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
