Old 01-01-2014, 09:39 PM   #1
crewcabshorty
crewcabshorty's Avatar
nv4500/205 shifter
I am in the middle of a nv4500 swap in my 1988 crewcab. It has a 205 transfer case. I am trying to find the best way to shift the transfer case. any ideas ?
crewcabshorty is offline   Reply With Quote
Old 01-02-2014, 12:29 AM   #2
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: nv4500/205 shifter
I really like the ORD twin stick set up I used for my NV4500 swap. They do not list the NV4500/205 shifter assembly on their website but they can make you one if you call them. Advance Adapters also makes a bracket that bolts to the transmission cover where you can use the original 205 shifter but it is really flimsy. I don’t recommend theirs. They're also some cable shifters out there for 205's but they are pricy, not sure who makes them though but the rock crawler types seem to like them.
ORD Twin stick
This was during mock up only and not the final assembly. I used heim joint on both shifter rails when it was all said and done.
This is the Advance Adapters NV4500/205 shifter bracket. It is horribly flimsy but could probably be reinforced to make it more solid if you really wanted to keep the original shifter. I took one look at this POS and ordered the ORD twin stick instead.
DirtyLarry is offline   Reply With Quote
Old 01-02-2014, 11:23 AM   #3
burnin oil
Could always have someone weld a bung on the 4500 adapter and then just use the factory shifter.
burnin oil is offline   Reply With Quote
Old 01-02-2014, 06:15 PM   #4
obijuan
ORD has the right idea there. i am very happy with my ORD shifters.
obijuan is offline   Reply With Quote
Old 01-03-2014, 10:05 PM   #5
crewcabshorty
Well I just ordered the advanced adapters bracket. I called them and they told me that they addressed the flimsy bracket issue by using thicker steel and a gusset. they also said because I am using the spacer between the trans and case that I need to lengthen the shifter rod on the transfer case to use the bracket.
Old 01-04-2014, 09:25 PM   #6
duallyjams
duallyjams's Avatar
post some pics when you get it
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
