Old 01-02-2014, 01:05 AM   #1
joeyc
72 c30 swap questions
Brake rotors for this c30 I have seem impossible to find and would guess pricey. Since it is a project, could I swap the suspension for say, 73 and up suspension/brakes as bolt on? Its a dually, and the rotors are the ginormous ridiculous mountain versions.
joeyc is offline   Reply With Quote
Old 01-02-2014, 01:44 AM   #2
farmall
farmall's Avatar
Re: 72 c30 swap questions
I pulled a whole front suspension out of a 73+ truck for my 71 for which rotors are NLA. For a 71 you can replace the spindle-out or the whole front end.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 01-02-2014, 01:46 AM   #3
joeyc
73 1 ton over to your 71 1 ton? Any mods?
Old 01-02-2014, 01:55 AM   #4
farmall
farmall's Avatar
I have not done it yet, but I did research here on the forum. To swap the crossmember-out you have to drill several more holes in the frame. To replace the spindles out you just swap the spindles, rotors, calipers. I dont think I remember anything about changing ball joints. Several forum members have done it. I am going to rebuild and paint the whole assy and also swap in a 14 bolt to get rid of the 4.56s. 73+ came with a sway bar as well.
Old 01-02-2014, 01:59 AM   #5
joeyc
Just going to ask you about the rear differential swap as well. I'm leaning at this point to either go with the 1 ton swap or cut the frame and swap over to 1/2. I have an retired California Conservation utility vehicle. I will post pictures tomorrow.
Old 01-02-2014, 09:34 AM   #6
mrolds88
Sure you have to swap spindles? I have a 72 C2500 that I did some research on a while back, and I thought that all the bearings were the same. I also thought the rotors were the same 3/4 and 1 ton srw from 72 up. Will have to revisit this. Just checked Rockauto and they describe that the srw rotors fit from 72 to 89. I would believe that the drw rotors would swap too
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 01-02-2014, 11:13 AM   #7
LockDoc
The Older Generation
LockDoc's Avatar
I'm headed out to the shop so I don't have time to look anything up for you but if you type the words "C-30 brake upgrade" into the GOOGLE search box at the top of this page, click on the circle in front of "67-72chevytrucks.com and click on the GOOGLE button you will find lots of threads on the subject.
Here is one of the most comprehensive ones:
http://67-72chevytrucks.com/vboard/s...d.php?t=367260
It is not C-30 specific but there is a lot of good info in it. It is on the '60-'66 board but would also cover the later trucks as the frame is basically the same...
LockDoc
Leon
Old 01-02-2014, 04:49 PM   #8
joeyc
LockDoc
Thanks. I will go over some posts now. Ultimately, it looks as I may consider selling if expenses far out weigh what I have in store.
Old 01-02-2014, 08:29 PM   #9
farmall
farmall's Avatar
NAPA shows the same p/n s for wheel brgs, calipers, ball joints, lower control arms 72-78 C30.
Upper control arms show different p/n s.
Rotors 73+ are 1 piece hub and rotor 1.54" thick. My 71s are 1 piece hub and rotor around 1.5 without pulling a wheel.
My Chevy parts book shows the same spindles C20&30 71-72 but the front brake page is missing.
I dont know why this has to be so difficult and why the parts houses show NLA.
I guess I will throw a 78 rotor on my 71 and see if everything lines up.
Unkle Matt never did say how his setup worked, or what he used.
I do know that forum members have put late 70s spindles-out on drum brake trucks.
Old 01-02-2014, 04:46 PM   #10
joeyc
Here are the pictures I mentioned that I would post. This is a 72 c30 4 speed granny low, with a non stock 327 circa 67. It is a retired California Conservation Corp utility truck turned work truck. The original red paint it came with is still in the interior and in places, exterior.
Old 01-03-2014, 12:59 PM   #11
joeyc
Is this common for c30 front suspension with the extra leaf spring supporting the lower a arms?
Old 01-03-2014, 01:11 PM   #12
farmall
farmall's Avatar
I thought it sat a lot higher in the front than my low rider.
First I have seen one of those.
Old 01-03-2014, 01:49 PM   #13
joeyc
It may be a special order because of its government issue? This may be hard to see, but a picture of the rear leaf springs. It also has some overload springs as well.
Old 01-03-2014, 02:22 PM   #14
LockDoc
LockDoc's Avatar
I lightened the picture up a little and rotated it so it is easier to see... That is some heavy duty springs for sure. Any chance you could post a picture of the sticker from the inside of the glove box door? Does it list any heavy duty springs as an option?
LockDoc
Leon
Old 01-03-2014, 05:17 PM   #15
joeyc
LockDoc
Here you go.
Originally a dual battery, dual alternator vehicle. Note the massive wiring sent to the utility bed in back of the brake booster, from firewall.
