Old 01-02-2014, 02:56 AM   #1
Tdubbyount
Tdubbyount's Avatar
Anyone build their own fuel cell?
So I'm thinkin about building myself a new gas tank. I got tired of screwing with my disfunctional dual tanks and one 16 gallon tank just didn't cut it for my particular driving style. So I pulled the tanks and filled up the space with my new 3" mandrel bent exhaust
Anyway, my plan is to build a cell that sits in the back under my toolbox. A "slip tank" as we call it on the farm. I thought about just buying one until I looked at the prices. And none of them would fit how I would like it anyway. So I'm looking for some pointers. What gauge metal? It's gonna be steel not aluminum. Most joints will be bends not welds. It's most likely gonna be Mig welded. I plan on having my filler inside the toolbox, with a vent outside somewhere. I want it to be somewhat discreet, since it's not exactly DOT approved. I think I'll be able to fab in a sender body off of a blazer or k10 tank I have. So what do you guys think? Anyone done this already?
Oh yeah, and I gotta show off the new exhaust I built...(:
1976...no...79...Chevy....wait...GMC shortbed 4x4. 5 inch lift on 35s, 355, sm465, daily driver. One day I'll figure out the story in that one.
1957 Chevy long stepper...not sure what I'm doing with that one yet. Awaiting funds I suppose.
Tdubbyount is offline   Reply With Quote
Old 01-02-2014, 04:41 AM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Anyone build their own fuel cell?
Why not use the blazer tank?
Your using dual shield yes? Use metal that's thick enough to put a good bead on but still easy for you to bend and fab with. I've seen some tanks built in an oval by taking sheet steel and bending it around a stump and welding the seam inside and out by having it overlap. Then side plates added a lot of different set ups I've seen on off road rigs some cool and some sketchy. If you look into how the NHRA specify a tank be mounted and built it will prob help with your build in reliability durability and safety.
A torch or plasma cutter and a nice mig can build you pretty much anything. Do you run gtaw at all by chance?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 01-02-2014, 08:36 AM   #3
willy41
willy41's Avatar
Here are some sealants you could use.
Mama Truck: 1996 S10, 4 cyl, 5 spd.
Papa Truck: 1973 Cheyenne Super 20, Camper Special, 3/4 K20 350, manual.
willy41 is offline   Reply With Quote
Old 01-02-2014, 08:58 AM   #4
mrolds88
Heres a good option. http://www.northerntool.com/shop/too..._541559_541559
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 01-02-2014, 12:12 PM   #5
willy41
willy41's Avatar
Originally Posted by mrolds88 View Post
Why do you suppose in its features and benefits section, it says:
Not intended for use with gasoline
Probably just some CYA thing; it says it meets DOT approval.
Old 01-02-2014, 04:38 PM   #6
Tdubbyount
Tdubbyount's Avatar
I like the design, but not the price...
Old 01-02-2014, 04:47 PM   #7
Tdubbyount
Tdubbyount's Avatar
Yeah I run tig in the shop, but I don't have my own I'll be doin this with a plasma cutter, a decent sized brake, and my little Lincoln 140 with solid .035 and 75% Argon/ co2.
As far as mounting goes I'm not quite sure what I'm gonna do. I dont want to just set it on the bed floor, it's gotta have something to set on. And I heard welding on tabs for bolting it down is a bad idea...? Apparently there's a reason gas tanks are strapped not bolted?
And I'm not using the blazer tank cause I have a 10 gallon air can mounted back there under my bed. Running out of space!
