Old 01-02-2014, 05:02 AM   #1
79bonanza
GPS speedometer
Ok I'm putting a 5.3 4l60e in my truck and need a speedometer. I was thinking of going with a GPS speedometer but does anyone know if a GPS interface would work with a factory 91 electric speedometer in my K5
79bonanza is offline   Reply With Quote
Old 01-02-2014, 11:01 AM   #2
Andy4639
Old member
Andy4639's Avatar
Talking Re: GPS speedometer
If you use the GPS speedo from speed hut you hook nothing else up to it. I just bought a rubber fitting and covered the trans mount up. Nothing hooks to it other than power ground and lights.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 01-02-2014, 12:17 PM   #3
ls1nova71
ls1nova71's Avatar
Re: GPS speedometer
I wasn't aware that anyone made a GPS interface that would run other gauges than the manufacturers specific gauges, but I could be wrong. Anyway, why not just hook your factory speedo up to the PCM and be done with it?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 01-02-2014, 01:06 PM   #4
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: GPS speedometer
I used the Autometer GPS and an Autometer electric speedo. When I was researching tho...seems like Dakota, Cyberdyne, and Intellitronix make "universal" gps interfaces capable of outputting 2-3 different signal types for various speedo requirements.
One gps adavantage I like is that my speedo is correct regardless whether my truck has its 275/45-17 Nitto's on... or my taller 315/60-15 MT drag radials on.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 01-02-2014, 01:32 PM   #5
79bonanza
Re: GPS speedometer
[QUOTE=ls1nova71 Anyway, why not just hook your factory speedo up to the PCM and be done with it?[/QUOTE]
I was not aware I could run my factory speedometer off the PCM output. Anyone have a wiring diagram for it.
