Fabricate till you "puke"
Elect fans going!
I have a pair of 14" flex a lite fans on a hand built shroud. I just got a chance to wire them today , & went for a test run. 95 degrees today, & she runs 190 on temp while moving, with the fans off. While idling in traffic, I can switch the fans on & drop temp to 185, then switch them back off. Its on a manual switch(for temporary). the 2 fans pull 1340 cfm ea, & are a tight fit on the shroud. Airflow feels pretty even all over the radiator with the fans running. the difference in power is noticeable after loosing the big flex fan that was on the truck! I still need to set up a thermostat to kick the fans,& paint the shroud all pretty.......but I like this mod
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
![]() Join Date: May 2002
i'd leave it with a switch, only because of the ability to turn them on whenever.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
Post Whore
![]() Join Date: Feb 2000
Course we want pics!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
I need to shoot a roll of film on the longhorn.......still dont have any shots of the trans swap that was done early this yr
14.1 @ 96MPH
It is entirely possible to wire it up so that a switch can override the thermostat...I'd have to sit down and work it out, but it wouldn't be too hard.
Project1970 - LS1 Swap Complete! ![]() |
#6 | |
Your UncleBen
![]() Join Date: Dec 2002
lata CHRIS
68 C10 shortbed -- Street/Strip ![]() |
Yeah. A manual switch and a temp. operated switch. Anyone know a coolant switch that fits in the thermostat housing you can get at the junkyard? I'd want a 180 degree one but that would have to come off an old car. Also in hot climates down South many use a 2nd small fan wired into the AC to keep the condensor more efficient and from exploding in traffic.
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint ______________________________ |
Spank 'em if you got 'em!
Just out of curiosity, why would you want a manual switch when you have a therm. switch? Isn't the manual option kind of redundent when you have the automatic feature? I'm not trying to make anyone mad, I really just want to know the advantage. Also, if the fans don't kick on to take the temp low enough can you get a wide range of therm. switches? I might consider going with an electric fan in the future and just got curious about this topic. Thanks.
Ro
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
14.1 @ 96MPH
The manual override is nice so you can turn them on and leave them on if they're cycling a lot, or if you're sitting in the staging lane at the dragstrip and you want to cool your engine a bit more...then you shut them off for the pass to save load on the alternator.
Got it!
