Old 01-02-2014, 04:36 PM   #1
scotzilla
1960 bed and cross sill/ bed support issue
bought a 1960 short bed fleetside project from a guy in pieces. Ive built a few of these trucks and have had to shim the bed, body and core support to obtain a straight body line but this 1960 is throwing me for a loop. I assembled the bed with the cross sills where they go according to LMC's catalog and it looks like im missing a frame stand off or some kind of spacer for the rear cross sill as its spaced about 2.5 inches off the frame. Am I missing something? All this pics ive found on the forum dont have the 60 style frame.
48 COE
69 c10
scotzilla is offline   Reply With Quote
Old 01-02-2014, 05:01 PM   #2
1963c-10
1963c-10's Avatar
Re: 1960 bed and cross sill/ bed support issue
There are one or two (can't remember) on the stepsides that just mount under the wood and do not attach to the frame. It may be the same case with the fleetsides.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 01-02-2014, 06:10 PM   #3
scotzilla
seems like the c notch pulled the back end of the frame down a little. To get the cab level with the bed id have to raise the cab 1/4 inch in the rear. Since there is all this work done to the suspension to lower the stance of the car, I am going to take out 1/2 inch from the front bed cross sill pedestal and then use some shims to bring it up level. The cab has new urethane body mounts and is measuring even to the floor on all 4 corners. Then after the front of the bed, cab and nose line up ill figure out what to do with the rear c notch portion. Im thinking slice it on the bottom side, get it to move where everything sitts level and square and then redo the notch.
48 COE
69 c10
Old 01-02-2014, 06:15 PM   #4
scotzilla
you can see how many washers we stacked to get the body lines to line up with the cab
48 COE
69 c10
Old 01-02-2014, 06:44 PM   #5
LVPhotos
LVPhotos's Avatar
Front to back large, large, short, large, crosseal. The short one goes to front wheelwell not like picture.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-02-2014, 08:11 PM   #6
scotzilla
yea that one was just chilling there after we tried to swap the front one out for the short one just to see if it would work. It was obviously way short
48 COE
69 c10
Old 01-03-2014, 08:44 AM   #7
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I think your frame rails are tweeted from the knotch.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-03-2014, 02:12 PM   #8
BadaSs_Cal
BadaSs_Cal's Avatar
Hey you didn't get that from Lodi did you? I might have done some welding on it
66 Gmc 1 ton. Long Step 351e V6
69 1/2 CHEVROLET (now a shortbed) LONGBED!:devil
61 Shortbed Fleetside 1/2 ton.. in progress
Next a 50-53!
MY BUILD THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=447926
BadaSs_Cal is offline   Reply With Quote
Old 01-04-2014, 01:34 AM   #9
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Did They Shorten The Frame And Not set it Straight.
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
