01-02-2014, 06:19 PM | #1 |
carpet
Has anyone have a good carpet source they would recommend. Its tough finding suburban stuff
65 burb On the road Mar 26th Finally |
01-02-2014, 09:22 PM | #2 |
Re: carpet
Hey man I used www.stockinteriors.com I got the truck carpet for the front and it covers from under the dash to where the plywood floor starts. I also ordered carpet by the yard and covered the rear..Great prices an quick shipping..
01-03-2014, 01:25 PM | #3 |
Re: carpet
Ditto on stockinteriors.com . Great selection on material and colors. They custom made mine with a lot of extra material hanging out of the mold so I had enough to cover back to the plywood area. Then ordered a roll of the same material to cover the whole flat plywood floor. A heat gun will get the small areas that need to be reshaped, like the RH door step.
01-03-2014, 11:44 PM | #4 |
Re: carpet
This is a great lead, but they don't show fit before 67? How did you get the earlier set up?
Scottie |
01-04-2014, 07:55 PM | #5 |
Re: carpet
Use Pickup, not Suburban :
http://www.stockinteriors.com/items....ard_Cab_Carpet You will want to call them and explain exactly what you want. |
01-04-2014, 09:25 PM | #6 |
Re: carpet
Thanks for the great info I will call Monday
03-31-2014, 10:47 PM | #7 |
Re: carpet
I had the local Auto carpet shop do mine back in the 90's. full floor, rear wheel wells, door bottoms, and kick panels-$500 total. I recently pulled all of it out, as I'm restoring it in memory of my dad, but kept all the pieces, so I can use them as "templates" when I have it done again. The hardest part, was re-installing the seat mounting plates in the carpet. When it was done, it looked factory. I'll try to get some pics of it on here soon.
04-28-2014, 04:27 PM | #8 |
Re: carpet
Quick question here I'm sure has been asked, and I apologize for asking again. For my '62 2WD Panel would I just order the carpet for a '60-'66 C10 2WD Pickup? I know the Burban carpets cover all the back area, but I have wood floors and don't want carpet back there. I can't find a site that specifically states it fits the panel. Thanks for the help.
Daily Driver: Dodge Caliber SRT4
Sunday Cruiser: '69 Camaro Convertible Project Car: '62 Panel Build Thread |
04-28-2014, 05:47 PM | #9 |
Re: carpet
Yeah, if your gonna use stockinteriors just call and order the one for the 62 pickup and let them know its for a panel so they can leave extra on the back side so that you can trim it to fit the area that you need covered.
02-25-2016, 11:40 PM | #10 |
Re: carpet
So I tried to order a carpet for my burb from stock interiors with extra material and was told I couldn't Don't know if he really checked into it or just said it was N.A. Has any one order one and what sales person you used ? Thanks Gary
02-27-2016, 05:26 PM | #11 |
Another carpet question - drilling holes
On the topic - I have another carpet question. I'm just now putting in a carpet kit, using the pickup kit and will add to it as have others.
I am putting in the Acoustishield kit and it looks pretty good. Dynamat and heatshield will improve the limo ride! BTW Quietride actually has suburban listings! My question is if there is a trick to running holes through the carpet for screws and bolts? There are seats, belts, gas pedal, and shift boot holes to deal with. The last time I tried to drill through a carpet I hooked a thread and caused a run across the carpet in no time. Thanks, Scottie |
02-27-2016, 07:48 PM | #12 |
Re: carpet
I used an ice pick first then an old phillips screwdriver I ground to a very sharp point. Then screwed the seatbelt bolt through the hole without any problems. I also did the same with the rear seat floor brackets.
02-27-2016, 09:05 PM | #13 |
Re: carpet
So Scottie can I ask where you got your carpet kit from and did it have extra material ? Thanks Gary
02-28-2016, 02:27 PM | #14 |
Re: carpet
I got mine from auto custom carpets www.accmats.com. They sell additional material by the yard. After the fact I saw that you can order some mass applied to the carpet in production.
I am still pretty happy with the http://www.quietride.com/ kit, although it is a little skimpy on the Dynamat. I just added more. See in process photo. |
03-01-2016, 01:57 PM | #15 | |
Re: Another carpet question - drilling holes
Put all of the screws and bolts in place before laying the carpet. Once you have the carpet in place use a razor blade to cut over each bolt and screw. It's much easier to find the bolt sticking up than the holes. |
