Active Member
BBC SBC New Pertronix Distributor & coil - $275
I have a brand new Pertronix distributor with proper matching coil.
Both are brand new Distributor is made in the USA part number D7100711 Includes built in rev limiter and multi spark modules built in to a small cap distributor Coil part number is 60103 This will fit into a standard deck big block chevy or a small block chevy Pertronix Flame-Thrower Ignitor III Billet Distributors are designed for maximum ignition performance and easy installation all at a price that you can afford. Replace your outdated points or electronic distributor with this performance proven distributor and which features the patented Ignitor III electronics and a CNC machined 6061 T-6 polished billet housing. Features: Multiple sparks throughout the entire RPM range Integrated digital rev limiter with LED feedback for precise RPM Memory safe function store settings eliminating unintended changes to rev limit Adaptive dwell maintains peak energy throughout the entire RPM range, reducing misfires while improving engine performance Synchronized peak current and park timing reduces heat build up Peak current level is reached just prior to spark for maximum energy without heat build up, increasing coil performance and module reliability Adjusts spark timing at higher RPMs to compensate for the inherent electronic delay Senses startup and increases energy for easier quicker starting Thermal clad surface mount construction for superior reliability Built-in reverse polarity and over current protection shuts down the system, preventing component damage Not compatible with C D or Multi-Spark boxes. Precision CNC machined billet housings are polished to a high luster. Tempered distributor shafts have low torsion displacement for accurate timing and longer life Upper ball bearing and extra long oil impregnated bronze lower bushing work together to reduce friction and high RPM vibration. High strength cap with male or female brass terminals and premium rotor with brass contacts Adjustable mechanical advance with proprietary limiting functions permits multiple settings. Distributors are factory set with a performance advance curve and are provided with additional springs for custom advance curves. Legal in all 50 states and Canada (C.A.R.B. E.O. #D-57-12). Note: Non vacuum advance distributors do not have an E.O. number and are not legal for sale or use on pollution controlled motor vehicles. I can take paypal, check or money order (all funds must clear prior to shipping)
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
![]() Join Date: Sep 2001
Re: BBC SBC New Pertronix Distributor & coil - $275
If the $275 includes shipping to Indiana, I'll take em.
Dan |
Active Member
Dan - PM Sent - & yes I will include shipping
Active Member
SOLD
Thanks You Dan
