Old 07-17-2003, 11:00 PM   #1
Ackattack
Ackattack's Avatar
Kickdown cable
Is the only purpose of the kickdown cable to shift to a lower gear when you get on it (such as passing) or does it affect other operations of the transmission?
I've had my truck for over 6 years and it has never been hooked up and I'm thinking maybe it's about time to go ahead and hook it up. I guess I've just been used to it not working, and this is my only auto vehicle I've owned.
Ackattack is offline   Reply With Quote
Old 07-17-2003, 11:02 PM   #2
GasHog396
You got it. On a TH350, it only controls the kick down.
'67 1/2 Ton Short Bed / 396 cid / AC w-R134a / 5 Lug Leaf spring rear axel / 5 Lug Frt Disk Brake Conversion
'97 Trans Am - Black / LT-1 / K&N FIPK Cold Air Kit / Hooker Cat-Back Exhaust / 160 Thermostat
'02 Buick Regal GS / Bone Stock
GasHog396 is offline   Reply With Quote
Old 07-17-2003, 11:22 PM   #3
cableguy0
it also controls when the transmission shifts partially
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 07-18-2003, 12:11 AM   #4
GasHog396
I alway thought the vacuum modulator is what helps the shifting on the TH350. The detent cable on my TH350 also hasn't been connected for years with no shifting problems, but let that vacuum line come loose, and forget about getting out of first gear, at least until the engine is screaming.
Old 07-18-2003, 08:45 AM   #5
Ackattack
Ackattack's Avatar
Yeah, during a cam swap I accidentally pulled that loose from the tranny and during my first test drive I was like WTF? Plugged the vacuum line back in and it was all good.
Old 07-18-2003, 09:10 AM   #6
Glen
the vacuum modulator on a th350 controls pump pressure based on vacuum response.
Glen is offline   Reply With Quote
Old 07-18-2003, 08:44 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The kick down cable will hold the gear longer. If you have it disconnected, you can't put it in drive and rev through the gears. I know mine will go into 2nd at about 4500, and into 3rd at about 3500 RPM. Once the cable was hooked up, it'll hold to about 5300 before shifting,a nd if I hold it in gead (as in hold it in first) it'll spin at least 6500. (I guess my govenor isn't working) I did this a few times.
If your vac line comes disconnected, you can shift it manually and it'll shift as long as you are at a good sppd. I had to do this recently when mine come undone and it was raining so hard that I refused to crawl under.
