Old 01-02-2014, 09:23 PM   #1
'65 chevy lover
Brake bleed question
When bleeding power disc/drum brakes, using the have a friend push on the brake pedal method, should the engine be running to make use of the power assist?
Thanks in advance for any help.
'65 chevy lover is offline   Reply With Quote
Old 01-02-2014, 09:35 PM   #2
RANDY COX
RANDY COX's Avatar
Re: Brake bleed question
Don't think it matters one way or another I've always bled mine without engine running.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 01-02-2014, 09:43 PM   #3
LVPhotos
LVPhotos's Avatar
You need to tell your friend to man up, even if it's your girl. ;p
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
