72 K10 350, Engine hugging firewall?
I've been in the process of replacing a leaking header gasket on my 72' K10 and I'm rather not happy. What was GM thinking put the small block against the firewall? I can barely slide a sheet a paper between the distributor cap and firewall, let alone get to the rear header bolts. Would I be better off taking the starter off and working from underneath? Anyone else complain of this problem or has my truck just put me in a bad mood?
Only other option I can think of is to take out the heater box for more room but geez I really don't want to do that. It would be a piece of cake on a 2wheel drive. |
Re: 72 K10 350, Engine hugging firewall?
You can swap in a 700r4 real quick. That will give you 3 more inches away from the firewall.
Grease Monkey
Every 1st gen truck I've worked on has had different spacing between the motor and firewall. I moved my engine crossmember forward 2 1/2" to fit my BBC.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053 Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12 |
Yup. Either move the T-case back and get custom shafts or move motor foreward.
GM pushed the motor back in order to create clearance for the differential housing and to keep a reasonable length on the front driveshaft. One reason I am a proponent of small cap HEI ignition setup so you don't have to hammer the crap out of the firewall.
Its tight but not that tight. I have a feeling that your cab mounts are toast and letting it all lean forward making a tight spot even more cramped. My stock Cap HEI fits with a little clerance. I can put a shorty wrench on the rear header bolt from the top also. The best thing I have done is buy header studs for the outer bolts. Holds everything in place and lets you put a socket on that sucker. Only downside is my headers are to close to the frame to install the header over the studs.
