Old 01-04-2014, 01:01 PM   #1
MILLER TIME
Drop Spindle....?
I am between the LMC drop spindle and the CPP modular drop spindle,
The LMC is 259$
2.5 inch drop
Uses stock joints and tierod
One piece design where caliper bolts
Claims to narrow track width 3/4" each side?
The CPP #CP30106-4 is 299$
2 inch drop
Claim to narrow the track width at least 1 1/8" between both sides
Uses a bracket to mount brakes that cost 75$ additionally...
If anyone has used the LMC spindle and can confirm that it actually does provide the additional tire clearance please comment because it seems to be the better deal especially when I have a gift card to Lmc but just not sure if I can trust there measurements bc I haven't been able to speak to anyone with them that can actually talk about there spindles...
Doin Work! Little At A Time....
MILLER TIME is offline   Reply With Quote
Old 01-04-2014, 01:03 PM   #2
MILLER TIME
Re: Drop Spindle....?
Any input is much appreciated! Thanks for reading.
Old 01-04-2014, 01:12 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
No one,... not even CPP has proven EXACTLY how much their spindles move in and compared to what?
I still challenge any suspension company to put the numbers down with associated pics to prove it.
Their Drop spindles compared to what?
1) Drum brake spindles?
2) 71-87 disc brake spindles?
3) other brands of drop spindles?
They need to:
1) Make a jig
2) install each different version of spindle
3) Measure to the "wheel mounting surface"
If they would do that,... then you would know.
I still say,... install your suspension,... and then install wheels and tire to fit.
Not the other way around.
Drop springs also affect these numbers, because they change the angle of the lower a-arm, thus pushing the spindle out as the spring gets shorter.
Keith
Convert to disc brakes.
Old 01-04-2014, 03:05 PM   #4
MILLER TIME
I believe your right. Just too hard to try and do wheel and tire before suspension is complete. This is my first big project, and I'm kind of learning as I go.
I have a Porterbuilt front dropmember so track width will be narrowed an inch and a half each side anyways but I'm planning on running the dodge steel 20's I bought a while back with those ****ty adapters and I thought if I could get a narrowed spindle as well it would ensure that I could lay out on those wheels and adapters...
Old 01-04-2014, 08:38 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You can save real money by ordering from Summit. Free shipping. They have CPP spindles for 230 and DJM for the same price. That's to your door price. LMC is gonna really whack you with shipping charges on top of their price.
Personally I'd run the DJM because they are a 3 inch drop rather than 2.5. I have them on my truck and like them.
Old 01-04-2014, 09:45 PM   #6
mgchevyparts
mgchevyparts's Avatar
They need to:
1) Make a jig
Good to see someone understands the BS that is put out there
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 01-04-2014, 10:07 PM   #7
lolife99
lolife99's Avatar
I would build the jig if I had all versions of drop spindles to compare.
Right now all I just have a set of Belltech 73-87 drop spindles.
I have Light Duty and HD rotors also.
We need to put an end to all the "supposed" facts .
Keith
Old 01-04-2014, 10:45 PM   #8
MILLER TIME
Well I appreciate the insight, going to do a little bit more research and order a pair Monday.
Old 09-12-2014, 04:54 PM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Any updates?
I think also read somewhere that the latest modular spindles - the ones they call "New and Improved" - now have the caliper mount cast in.
Is is it true we don't need to buy the caliper mounting bracket anymore?
66 C20 Service Truck:
Old 09-29-2014, 02:50 PM   #10
LostMy65
LostMy65's Avatar
Old 10-02-2014, 04:59 PM   #11
truckfan
truckfan's Avatar
lurking
1981 Chevy C30 440 Holmes 42K one owner miles
truckfan is offline   Reply With Quote
Old 10-02-2014, 08:37 PM   #12
Lost81c10
Lost81c10's Avatar
Originally Posted by LostMy65 View Post
Any updates?
Don't know if the Question is in reference to the cpp but I got the 2.5 (1 1/4) last year for my 85 and did not have to get any extra brackets for the calipers. Hope this helps in your question.
Mando
Lost81c10 is offline   Reply With Quote
Old 10-05-2014, 10:04 PM   #13
LostMy65
LostMy65's Avatar
The Modular are only a 2" drop.
2.5" drop are the regular cpp spindles that have the caliper ears cast in.
Old 10-05-2014, 10:09 PM   #14
Lost81c10
Lost81c10's Avatar
I see. Sorry about that.
Old 10-05-2014, 10:16 PM   #15
LostMy65
LostMy65's Avatar
Hey, thanks for trying to help out.
Old 10-06-2014, 12:19 AM   #16
jrfonte
Not sure if this helps but just ordered these about 2 weeks ago and installed them with no issues other than having to clearance the lower a arm for the 15x10 wheels to fit back on. They were around 170.00.
jrfonte is offline   Reply With Quote
Old 10-06-2014, 12:38 AM   #17
CircusWagonJim
CircusWagonJim's Avatar
More confused now. Do you need to buy seperate caliper brackets for the DJM spindles?
CircusWagonJim is offline   Reply With Quote
Old 10-06-2014, 06:36 AM   #18
lolife99
lolife99's Avatar
Not that I know of.
Should be the standard spindle design.
Only the CPP modular spindles use a separate caliper bracket.
Keith
Old 10-06-2014, 07:07 AM   #19
jjzepplin
jjzepplin's Avatar
Do they make these for the 1.25" HD rotors?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 10-06-2014, 02:48 PM   #20
jrfonte
Yes they had those for the 1 1/4 hd rotors.
If I would have known when I bought them that I could covert my brakes to the bigger size so easily I would have bought them because I replaced everything spindles calipers rotors and shoes. didnt know all that was required to just buy the new 1.25" parts. And swap the mc to the hd version. Would have worked better with my rear disc conversion i think.
Old 10-06-2014, 08:55 PM   #21
1977cheyenne_C10
1977cheyenne_C10's Avatar
is that brand CTS good? never heard of them
1977cheyenne_C10 is offline   Reply With Quote
