Old 01-04-2014, 05:01 PM   #1
1ndatrunk
Gear ratio for cruising and mpg
Hi guys. I recently swapped in a rear from a 74 2wd c10 with a 305, into my stock 2wd 88 tbi/700r4 Suburban because the axle took a crap on me. I have no idea what the c10 ratio was, nor do I know what was originally in my suburban. What I do know is that my speedo is reading 10-15mph lower than actual speed, and that the truck seems sluggish.
I know I can get a new plastic gear to help with the discrepancy in my mph reading, but what about the sluggishness? Is there a gear ratio that would give me some decent pep, while still having good mpg and a low cruise speed? My friend mentioned 3.73 gears, but wouldn't that cause me to cruise at too high of an rpm? I plan on going bone yard pillaging in the next week or so, so can you guys help me out? I'll also be adding 26" rims/ with low profile tires in the next couple of months also, if that makes a difference.
Thanks in advance
1ndatrunk is offline   Reply With Quote
Old 01-04-2014, 05:08 PM   #2
cal30_sniper
cal30_sniper's Avatar
Re: Gear ratio for cruising and mpg
3.73s work great with a 700r4 and the factory tire size. That's what I had in my '90 R1500 Suburban (350), and it was capable of knocking down 16-18mpg. With a 26 inch tires, you might look at stepping down to a 3.42 ish gear. The ratio is easy to count, just turn the tire one revolution and see how many times the driveshaft rotates. That's your ratio.
86 Chevrolet K20/30 Suburban - 8.1/NV4500/NP205/Dana 60/14 bolt FF, build in progress
73 Formula - 400/Doug Nash 4+1, resto on hold
86 Chevrolet K30 3+3 - 350/TH400/NP241, Air Force/Forest Service Rescue Truck, for sale
01 Ram 2500 - 5.9L Magnum, daily driver
91 BMW 325i - Chumpcar series racecar
cal30_sniper is offline   Reply With Quote
Old 01-04-2014, 05:54 PM   #3
1ndatrunk
Would the 3.73 and the 3.42 give me the ability to make a little wheel spin off I wanted to?
Thanks for the quick reply
Old 01-04-2014, 06:38 PM   #4
cal30_sniper
Depends on tire size and engine mods. I had Vortec heads, a performer intake, quadrajet, HEI, full tube headers, and dual dynomax exhaust on my 350. The peg leg rear in it could do a decent job of tire spin when you wanted to. The warmed up 454 I have in my current burb can spin all you want, even with 32" tires and a locking 14 bolt rear. I really like the 3.73 ratio as long as you've got a truck with an overdrive trans. Its about as high as I'd want to go with the steep 1st gear in a 700r4 though.
