01-04-2014, 07:05 PM | #1 |
Once again ... Need Help
Ok the truck is still a 71 SWB. At least for now cause I may have to blow it up. Lol. When u drive it, it sounds like a window is open. So I taped the door and drive it and it stopped. I have replaced all rubber seals, vent windows are new, and everything else but the darn doors themselves. The lines of the truck line up and it still sounds like the window is down. Even put sound deadening in. Any idea why this is happening ? It's driving me crazy....
01-04-2014, 07:25 PM | #2 |
Re: Once again ... Need Help
Tape off sections of the door till you find the area leaking air thru. Then get creative, figure out if its pinching the seal because its to tight...if so i have had good luck with putting a towel in the door jam and shutting the door to help space the gap aliitle better. It will mold the metal alittle and push it out. If its because its not tight enough i have someone get on the inside and hold the door open while i push on yhe window frame rail. Aliitle red neck i know...but seems to work on these old trucks...
01-04-2014, 07:54 PM | #3 |
i suppose you could put a bead of something that will wash off easily on the rubber all the way around, then close the door. when you open it look the spot(s) that didn't transfer to the door.
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Survivor "Lil’ Mint" (67 c10 40k mile light green original paint) Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
01-04-2014, 08:27 PM | #4 |
The '71 has those nice car-style door panels. A layer of clear sheeting between the door panel and door, like many cars do, might help to deaden the sound. Wind noise from the mirrors can be amplified by that big hollow metal door, and get pretty annoying. Westsong, that shop towel fulcrum or brute force tweaking of the window frame was the procedure Honda recommended to resolve wind noise complaints from poor seal fit, back when I worked for them. I've used it with many other vehicles.
If 'that which does not kill me, makes me stronger', then I should be Superman by now! |
01-05-2014, 02:33 PM | #5 |
I would think you can ID the problem area on your door by using a manila folder and closing the door with it sticking through the door checking for the amount of resistance in different places and pulling from either the inside or outside of the door jam. Then concentrate on a fix.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
01-05-2014, 03:14 PM | #6 |
Thank you all for the help.
01-05-2014, 03:27 PM | #7 | |
Good luck to the OP in finding the leak. Perhaps new door seals?? regards JohnG |
