Please allow me to introduce myself
Hello to everyone . My name is Pete and I live in Odessa , Tx. I recently picked up a '57 Chevy Pickup . It is in pieces with a lot of stuff missing and the top chop was already started on it . I got a frame from a '56 with another cab that is pretty bad but , I should be able to use it to finish the chop or repair it back to normal top . I also got a partially complete '77 Camaro that I am going to use the subframe out of . I have a choice of a stepside bed or a '59 Apache fleetside bed to use . I have a complete '93 z28 that I may use the drivetrain out of but , I haven't decided on that yet . It will be a while before i am ready to put an engine in it .This is my first build like this but, I am excited about it . This forum is AWESOME !! I will probably be here everyday . I get more excited every time I visit the forum . Oh yeah , I got titles for the '57 and the Camaro .
Re: Please allow me to introduce myself
Looks like fun, a lot of people that tried the top chop had problems when it came to putting in the windshield. Maybe starting with a cut down windshield before welding would help, Enjoy the group.
Retired and too busy to work. |
Great project. My vote is fleet side. I like the looks, if I didn't already have a step side I'd do fleet. When I first got into these trucks 20 plus years ago I didn't like then but I do now. Looking forward to seeing which direction you go.
-Aaron '15.5 Chevy Duramax LTZ/Z71, LML, CC/SB '77 Chevy K10, 4" lift, 33-12.50, 350/350 '55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD) My 55.2 Chevy 3100 Build |
Hi Pete!
I'm Nick, and welcome to the board! It looks like you have a solid start on your project. Seems like you have enough parts to make a crew cab - a chop top crew cab. (man that would be slick) So what's next on the chopping block? |
welcome Pete!
I look forward to following your progress! if you don't use the stepside bed, contact me with some pictures if its in nice shape. ive been looking for a while
Frank 1957 Chevy 3100 2000 Silverado z71 SOLD 2012 Ram 1500 Quad Cab 1992 International 4700 |
Welcome to the forum. I love the Tri Fives.
av8tr33337 AKA Bartman ![]() Bartman's Ad-S10 Chassis Swap http://67-72chevytrucks.com/vboard/s...d.php?t=415418 My First Youtube Video http://www.youtube.com/watch?v=B6hSt...eature=channel More Pics of the 51 Project http://s668.photobucket.com/albums/v...hassis%20Swap/ 1951 3100 Pickup |
welcome to the forum from sin city - enjoy the ride !
![]() Join Date: Mar 2011
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
Welcome and be prepared for some long hours of sitting and reading on this site. Even a novice could build a truck off of the expertise around here.
It looks like you are off to a great star with parts. I'd be using the Camaro for whatever you can. Use the 77 subframe as well as the fuel injected power train out of the 93 to save a lot of time and cost. I'll be watching for a build thread to start on this one
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
Welcome.
Sounds like a great build no matter which way you decide to go. Kim |
Thanks for the welcome guys . I plan on starting with the frame , getting it cleaned up and the Camaro sub welded on and rebuilt . I am going to do the graft with the truck frame on top of the sub . I have seen several on here and I think that is the best way to do it . I am going to be on a budget so it will be a slow build . All of you guys on this forum are an inspiration . I hope I can end up with as nice a truck that some of you guys have built .
I have never tried anything like this before so I appreciate the advice . I have been reading and watching videos about cutting down the windshield and it seems that what you suggest is the preferred way , so I will most likely try it that way . I need to get a windshield first though , hehe . I was also thinking I will make a fiberglass copy of the windshield so I can get the shape worked out before I try to trim the glass . I have seen other people do that .
#13 |
Just remember if you go with the top chop, tack the top on but before fully welding and finishing it on the front at least, make a template and have the windshield cut. You will need the windshield to cut to modify the roof to fit it. You could also make a good template of the glass, I did one out of fiberglass for one of these trucks years ago. You can then trim that template, you will be making template for the glass cutter as well as making your template to modify the opening in the roof so you don't have to be handling a piece of new glass for this purpose.
But lower corners of the windshield post must be modified anyway you look at it. Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
#14 |
![]() to add to martinsr's post: cut and fit your windshield before you weld the top on, you must fit the frame to the cut glass. i have only seen one curved glass chop work with cutting the glass to the frame. i consider him lucky. most chopped task force cabs go to the scrap man because the fabricator under estimated the work and fitment involved.
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#15 | |
#16 | |
#17 |
Here is an example of why you need to modify the roof to fit the glass. I took this photo at a show last year so I would have it. Notice how the corner of the glass doesn't fit into the corner of the opening? It's suppose to be "tucked" down into that corner.
The problem is when the glass gets shortened the top of the glass ends out further than it did originally, thus the window gets leaned forward. I think to repair it ascetically would be to bring the top of the glass back instead of building up this corner but that would be a lot more work. Brian ![]()
#18 |
In looking at that photo, it looks like it isn't tucked all the way in at the top either, this would make the bottom even worse. But still it wouldn't go back far enough to make the bottom correct. There just isn't enough glass there to do it, plain and simple.
Brian
#19 | |
Making the roof pieces fit is the easy part, you just cut and weld and lengthen and what ever else is needed. The issue with the glass is you can't cut and weld and lengthen glass. ![]() I have only chopped one of these trucks and when I did I simply made pieces to fill the gap of the widening of the roof using pieces I cut off, what most guys do being they don't have an extra roof. Personally, you can do this but the accuracy of your cars have to be mad perfect, pretty tough to pull off. If you cut the roof in half and put it down making it straight, tack it into place at the pillars then make a piece to fill the gap it's way easier. Not quite as clean as if you only had one weld there, but much easier. On the one I did what really helped alot was that I cut the skin off the top I was chopping, all the way around the top leaving only a few inches around the top and sides. The rear I kept it all the way up until it flattens out. After chopping the top and making the pieces to fill the gaps and tacking them in, I then cut the skin off the donor top a little bigger than where I did on the chopped one of course and fit and welded it in. That way there was no cut across the middle of the roof which would be much harder to weld. I MIG welded the whole thing a little at a time around the edge and ended up with very little filler. I may do things different today, but that worked out pretty well. I also didn't flange it all the way around, that would make it MUCH easier than what I did and much cleaner. But that was before I knew about such a procedure as flanging. Brian
#20 |
I must be the guy Ogre is referring to, but I did trade out work to a naturally talented metal guy to cut my top. A couple of weeks of sleepless nights and three windshields and a conference between the metal guy and the glass guy but the windshield works. It is close to having the corner problem in the above photo as the gasket barely makes the glass and metal fit and look good. So the above advice is probably the best to follow, but I'm here to say the worry and heartache is worth it when you see the result. Now that mine is together and almost on the road, I wouldn't trade the look for any I've seen.
#21 | |
#22 |
![]() Join Date: Jul 2006
Welcome! Nice project start.
My neighbor has this sweet chop-top '59 big back window. If you have questions he likes to talk about the chop and the fun he had with the glass (multiples). I'd be happy to ask him about specifics or take some close-up pics.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#23 | |
Brian
#24 | |
LOL, I had a very inexperienced glass guy break THREE windshields too! Before I talked to someone who explained about the "hole" not being right and needing modification. Brian
#25 | |
Brian
