![]() Join Date: Jul 2013
65 panel build steering column
Looking for a floor shift steering column for my 65 panel. Currently have a 3 on tree and it is ugly. Running a Muncie 4 speed behind a built 350. would like to clean up both dash area and firewall as steering shaft is going into a 2003 Ford Crown Victoria R&P front end. Anyone got one would just make my new year complete. Thanks.
Re: 65 panel build steering column
I may have one. I am going to pick up a 1 ton next week to cut the roof off of it and it has a 4 on the floor. You can have it for 50 plus shipping with out the shaft if I get the truck.
Hey bud! Sounds like a good panel! I'm in the market for a 3 on the tree steering Colum! Is the one your removing in good shape? Haven't been able to find one at the yards
I may have one. I can check tomorrow if your interested,mark
It was you, ill check tomorrow,mark
Youngrasta66. I can check, I personally never used it because Panel already had a floor shift on it when I got it. By the condition of the rest of the panel I would think it is ok. I can check tomorrow.
Thank you both very much!
I have 2 that you could probable make one good one out of them. One is still in the truck and has not been cut, the other one has been cut. The shift arms need to be rechromed , mark
whats ur plans for the colum shifter? another fourm member needs the light cover inside the colum for the gear selector lens
| Bookmarks |
