Old 01-05-2014, 07:30 AM   #1
Bullett
Under dash heaters
Has anyone had any luck with any of the under dash aftermarket heaters? I see a few on ebay that appear to be relatively simple and reasonably priced, just curious if they work decent. Thanks...
Bullett is offline   Reply With Quote
Old 01-05-2014, 01:26 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Under dash heaters
SpeedwayMotors.com out of Nebraska has one small simple.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 01-05-2014, 07:03 PM   #3
Bullett
Great, I will check it out. Thanks.
Old 01-05-2014, 07:18 PM   #4
Bullett
Originally Posted by Woogeroo View Post
Are you looking for a different type of heater or a replacement for what you have?
-W
The heater in my truck doesn't seem to work? I haven't had much time to look into it yet but I was thinking if the under dash type heaters work well and are reasonably priced, I would just do that. I noticed that the heater hoses that come through the firewall are plugged off so the heater isn't even plumbed up. I guess I'm just assuming that it doesn't work?
Old 01-05-2014, 07:23 PM   #5
Bullett
Maybe the heater core was leaking, so they stopped it up. If the fan stops blowing that would keep it from working as well.
Check the 60-66 FAQ, look under 'heaters'. There are several threads there about heaters in our trucks. The thread 'all about heaters' is where you should start.
Generally speaking, our heaters can be rebuilt.
-W
Awesome, Thanks. I'll check it out.
