Old 01-05-2014, 11:59 AM   #1
dyno
dyno's Avatar
Inner Cab Corners or Not?
Finally getting around to replacing steps and cab corners on my 58. I have seen where some guys have decided not to replace the inner cab corners since the area is so rust prone. If I do replace them, I think I'll plate off the gap in the top of the floor on each corner. Thoughts?
"Built- not bought"
1958 GMC 150 4x4 in progress
1980 K20- Restored
1985 K3500 Flatbed
58 GMC 4x4 build thread:
http://http://67-72chevytrucks.com/vboard/showthread.php?t=557675
dyno is offline   Reply With Quote
Old 01-05-2014, 01:20 PM   #2
Flames97
Flames97's Avatar
Re: Inner Cab Corners or Not?
When I do my cab corners I'm leaving the inner out. And just capping the too off. I think it looks cleaner and there won't be a chance of trapping dirt or moisture in there.
-Aaron
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 01-05-2014, 02:49 PM   #3
jackson
-Aaron
will that work on an ad also
jackson is offline   Reply With Quote
Old 01-05-2014, 02:51 PM   #4
Flames97
Flames97's Avatar
I'm not sure, I don't know how the ad cabs are setup in that regards. I'm sure some ad owners will chime in.
-Aaron
Old 01-05-2014, 03:09 PM   #5
OrrieG
OrrieG's Avatar
I rebuilt mine, repop metal was not available, with drainage holes. This truck is going to be used daily and will go off road just like before so I wanted to stiffen up the corner. I enclosed the top at the cab after realizing years of hosing down the inside after muddy camping trips probably cause the corner rust. Details are in my build thread toward the start.
OrrieG is offline   Reply With Quote
Old 01-06-2014, 01:05 AM   #6
roger55
roger55's Avatar
I'm leaving the inners out on my '57. I see no good reason for having them.
roger55 is offline   Reply With Quote
Old 01-06-2014, 01:25 AM   #7
SCHRUMGMC
SCHRUMGMC's Avatar
Only thing I can think of is that you'll find things in there over the years....Makes me debate on closing mine off or leaving it
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 01-06-2014, 09:49 AM   #8
JML55
JML55's Avatar
I cut mine out and cap the floor, and put a small brace from the edge of the cab corner to the floor . But yes today you can buy repo inner cab corner piece that would be much easier to replace then trying to fix rusty old ones.
Jean-Marc Lacasse
57 GMC
55 GMC
55 Belair
99 S10
http://67-72chevytrucks.com/vboard/s...d.php?t=316140
http://67-72chevytrucks.com/vboard/s...d.php?t=806011
JML55 is offline   Reply With Quote
Old 01-06-2014, 10:03 AM   #9
dyno
dyno's Avatar
Since I had them anyway, I decided to replace them. Before I installed the outer corners, I traced the contour for the floor caps.
Had a pretty productive weekend. I got everything sectioned and replaced including step/rocker, cab pillar, hinge pocket, inner and outer corners. Next weekend I'll do the other side. Should go a bit quicker.
"Built- not bought"
1980 K20- Restored
1985 K3500 Flatbed
Old 01-06-2014, 03:31 PM   #10
OrrieG
OrrieG's Avatar
If anyone is interested I have the inside corner infill template saved as a jpeg. message me with an email address.
Old 01-06-2014, 04:43 PM   #11
roger55
roger55's Avatar
Son of gun.
I'm wanting to make mine now. I was just looking on how to make a template.
Talk about good timing!
PM sent.
Old 01-07-2014, 02:34 AM   #12
Chapo_76
Chapo_76's Avatar
Please send it to me....... Thanks
Mrios_76@hotmail.com
Chapo_76 is offline   Reply With Quote
Old 01-07-2014, 03:46 AM   #13
tpimuncie
tpimuncie's Avatar
Any pics on left front lower cab pocket? My cab was hit and trying to see how banged up it really is
1959 apache 1948 chevy coupe
http://67-72chevytrucks.com/vboard/s...d.php?t=562949
1964 gmc burban build for pops
http://67-72chevytrucks.com/vboard/s...d.php?t=724632
tpimuncie is offline   Reply With Quote
Old 01-15-2014, 12:34 AM   #14
DBL_NKL
Great info Orrie. Just sent you a PM as I need to do mine in the coming weeks. Cheers
DBL_NKL is offline   Reply With Quote
