Old 01-05-2014, 05:06 PM   #1
doubeys_nova
1985 K10 LSX swap computer relocation
I roughed in an LSX swap in my K10 2'ish years ago and have been driving/working out the kinks. Along the way I have found that having my computer and fuse block mounted in the engine bay is unsightly and annoying. I have the truck disassembled right now for body work and want to relocate those two things inside under the dash.
After setting the inside heater box in I do not see any clean accessible options. Every place I tried was not even close to fitting the computer let alone a second fuse block with relays.
I am looking for someone that has mounted at least the computer inside, under the dash.
I big thanks ahead of time for any help, input and ideas.
doubeys_nova is offline   Reply With Quote
Old 01-08-2014, 10:20 AM   #2
solidaxel
solidaxel's Avatar
Re: 1985 K10 LSX swap computer relocation
O K, no pictures yet !
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 01-08-2014, 11:07 AM   #3
doubeys_nova
can not load pictures.
Old 01-08-2014, 11:40 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I have seen where some guys mount the Computer behind the glove box, on the firewall. I havent seen anyone put a fuse block anywhere but inside the engine compartment.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-08-2014, 11:56 AM   #5
doubeys_nova
i was looking last night and decided the only option is to block off the middle floor heat opening and build a little box that goes from the trans tunnel to the dash and mount it into that. i dont have enough wire to go under/behind the seats. i will just have to make sure i can easily pull the box so i can do any maintenance on it in the future with taking the truck apart. the inside heater box takes up a lot of room and then the ductwork takes up the rest.
I thought about mounting them to the glove box but the fuse block wouldnt fit with the ductwork. tons of room everywhere else. just not in the dash.
Opinions on cutting a hole in the floor and setting the computer in a sheetmetal box with a metal cover. all you would have to do is pull the carpet back a little if you ever needed to get to the computer. anyone that looks under the truck would probably notice a ~12"x8"x3" box sticking out but is that really that bad of an idea? in my head it seems like a good idea.
Old 01-12-2014, 08:37 AM   #6
solidaxel
solidaxel's Avatar
You do make a good point about mounting the computer under the floor!
I ordered my harness with the standard tail of 4 ft , now I think 6 ft would have put under the seat.
I am going to look at a spot under the floor away from the exhaust
LS 3 4L70E
