Old 01-05-2014, 06:32 PM   #1
8door
Not too old to learn
Changing carrier bearing help !
I bought a used drive shaft and need to install a new carrier bearing.
The used one has a flange on eithr side of the bearing, I assume is a
stone guard, but I can't pull the pinion yoke off. It is stuck firm.
My exsisting shaft didn't have the guard flange so I want to know is there
specific method needed to separate the yoke ? The old one came off easy
well real easy the the shaft split.
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 01-05-2014, 08:28 PM   #2
bigmac73
bigmac73's Avatar
Re: Changing carrier bearing help !
Pics would help out, thanks
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 01-05-2014, 10:40 PM   #3
Daner
Daner's Avatar
You mean you can't separate the shaft? Or you can't get the driveshaft off the rear axle?
If the shaft won't separate try pump some grease in the fitting.
My bearing was froze solid to the shaft so I used a torch and cut it off avoiding the rock guard. Mine only had a guard in front of the bearing. When reassembling make sure the yokes are lined up correctly.
Good luck. Sorry if I misunderstood.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 01-05-2014, 11:12 PM   #4
1967chevy c10
Hey new to the site. I wound mark the yoke and the shaft with a paint marker so you can line it back up. Plus I wound change the u joint too since you got take it out. I'm doing my tomorrow lol
1967chevy c10 is offline   Reply With Quote
Old 01-06-2014, 01:15 PM   #5
8door
What I have is a broken drive shaft I took it off my truck then went out and bought a used one, also out of the truck both are sitting on my work bench.
The broken section is the splined shaft of the first shaft, the one between the transmission and the carrier bearing.
The used one is all together, I need to remove the yoke next to carrier bearing so I can change the old carrier bearing with a fresh new one. The yoke is stuck to the shaft....that is the problem. Ujoints came out OK.
Here are pics of old broken off my truck and used I bought. I cut the carrier bearin housing off to see what the two flanges look like.
I could take the whole thing to a drive line shop for them to seperate the yoke from the shaft, but wanted to see if you all might have a tip to get it done.
Old 01-06-2014, 02:24 PM   #6
msgross
msgross's Avatar
since you have a spare yoke now I'd try a gear puller on the used one. "should" slide off the splines and then you can pull the bearing off.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 01-06-2014, 03:29 PM   #7
Sammy
You are this far I would just take it to a drive line shop let them reassemble and balance. The ones I removed were with a hydraulic press (best) and a torch without a press available. The right gear puller combination is a good recommendation too.
Key is if your replacement parts are good quality stuff. You hate doing this again in 6/ 12 months.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 01-06-2014, 03:33 PM   #8
leddzepp
Moderator
leddzepp's Avatar
X2. Inland Empire driveline is right down the street in Corona.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 01-06-2014, 03:41 PM   #9
brad_man_72
the boat guy
brad_man_72's Avatar
Since you have to take it to a driveline shop to have it ballanced anyways, have them do all of the work and make sure the used shaft you bought is worth repairing. Take both shafts. There's much better carrier stubs oavailable now than when these parts were new 40 years ago.
Any time you repair anything on a 2 piece shaft it needs to be reballanced as an assembly, even if you mark everything.
Take the bolt out of the carrier yoke. Secure yoke, drive carrier stub through yoke. Remove shields (put them in the trash). Cut the old carrier bearing off (don't use a torch heat warps steel). Drive new carrrier bearing on. Bolt on yoke the same direction as when it was ballanced last or in time if somebody else already messed it up making sure the bolt will actually tighten the yoke on the stub (many won't). Reinstall rear shaft the same way it was ballanced last using a good spicer or neapco ujoint (shim joint to remove any endplay or at least make sure the keepers are installed). Take to a driveline shop to have the shaft ballanced as an assembly.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 01-06-2014, 03:44 PM   #10
67 chevelle
67 chevelle's Avatar
x3 the balance thing might come back to bite ya switching parts out ,should be cheap to have a driveshaft shop do and , will be done right
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 01-06-2014, 04:41 PM   #11
8door
I was planning on trashing the sheilds , as they will get crushed in a press anyway.
Balance the whole assembly including the ujoints, both shafts and the carrier bearing right ?
Old 01-06-2014, 09:51 PM   #12
brad_man_72
the boat guy
The shields usually come off pretty easy.
You got it! Just imagine that every part is not straight or centered. The carrier stub/bolt on yoke and ujoint are swinging the rear shaft around, not just spinning but a circular motion. Ballancing doesn't make the shaft any straighter it just keeps the shaft from shaking. Now if you move any of those parts around the ballance will change.
Now even with everything marked something that would seemingly not change the ballance like changing the carrier bearing actually will affect the ballance. Either due to parts not fitting the exact same as they did before or the ujoint being installed slightly different. It doesn't take much of a vibration to kill the carrier bracket on these trucks. On other vehicles a ballance problem will just beat the rubber to death.
