01-05-2014, 08:05 PM | #1 |
Old member
LSx power steering and drive shaft ?'s
The shop wanted my old fitting off the orignal power steering pump. Is that all they need to swap it out? I got it out and was wondering if they needed anything else. They have new hoses already for it.They wanted a new yoke for the drive shaft also, said the one on it now didn't fit the 4l80e trans. I thought 700 r4's and the 4l80e were the same size. I don't have the yoke but he said he could get one. Just wondering going tomorrow to take them the P/S fitting.
01-05-2014, 09:10 PM | #2 |
Fabricate till you "puke"
Re: LSx power steering and drive shaft ?'s
The shop told you straight, On both counts....Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-05-2014, 09:39 PM | #3 |
meowMEOWmeowMEOW
....Did you pay a shop to do the swap, and the come here second guessing them?
wag of the finger
01-05-2014, 09:57 PM | #4 |
4160's and 700's are the same but the 4l80 are much bigger yoke. I have had some power steering lines screw right into the new power steering pumps and some have to be adapted... so I'm sure Hawks is steering you right.
Good luck |
01-05-2014, 10:20 PM | #5 |
I just swaped the fittings and used the stock 71 lines
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
01-06-2014, 04:46 AM | #6 |
4l80e uses the same yoke as a 400 turbo.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
01-06-2014, 09:22 AM | #7 |
Old member
Thanks for the info guy's.
No I'm not second guessing just want to make sure thats all I needed before I make the trip over there. Don't want to make the trip and findout I needed something else is all.
01-06-2014, 05:37 PM | #8 |
That is what I did on my 78
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
01-06-2014, 05:39 PM | #9 |
The TH350 in the 78 fit in the 4L60E
01-06-2014, 06:37 PM | #10 |
Old member
All is good. Took the fittings and old lines back just incase and they needed the length for the new ones. The yoke on the old shaft was to small + they had to cut it down 1 1/2" to fit so that is done also.
01-06-2014, 10:03 PM | #11 |
Yes that is correct, 350 turbo is the same as 700r4/4l60e, and the 4l80 is the same as a 400 turbo, basically just with overdrive added.
01-07-2014, 03:36 AM | #12 |
meowMEOWmeowMEOW
FYI you need special fittings for the 4l60e and 4l80e trannies when you hook up the tranny cooler, unless you are using O.E style push connect fittings. They go INTO the trans a little bit, and using any other fittings are problematic. If you are running braided lines or need to use aftermarket connectors for some reason, these fittings are a MUST.
Thats the only other thing I can think of that might come up as an issue if the shop didn't have it on the parts list (but this completely depends on your setup)
01-07-2014, 09:03 AM | #13 | |
01-07-2014, 10:30 AM | #14 |
Tell us more about the special fittings!
01-07-2014, 10:57 AM | #15 |
..I used the stock fitting for the power steering. and these for the trany fittings...the one is longer for a reason.
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 Last edited by mooseknuckles; 01-07-2014 at 11:03 AM. |
01-07-2014, 11:21 AM | #16 |
I think this is what BR3W CITY was talking about, the longer fitting for a 4l80e. The 4l60e you can use the older flare fittings out of an older transmission.
01-07-2014, 11:26 AM | #17 |
Thanks!
01-07-2014, 07:59 PM | #18 |
meowMEOWmeowMEOW
YES, sorry if I made that more confusing for you guys. Failure to use the correct fitting on the (80's if you switch) can result in lack of line pressure, and goofy tranny issues. The depth on the fitting is critical, and is often missed because the stock line has this depth built into it.
BUT for the 4l60e, I should add that it gets a bit weird; you CAN use your old fittings, and you CAN use aftermarket fittings BUT....the tranny case is cut to 1/4" NPS, the S standing for STRAIGHT CUT. Many common fittings are cut to NPT, which is the Tapered National Pipe Thread. Technically, using the wrong fitting can leak or work its way out. That being said, people throw loctite on NPT and use them all the time. I realize I got on the 4l80e mind track again.
01-07-2014, 08:56 PM | #19 |
Old member
Trans was no problem had the stock fittings with lines they just adapted over on the radiator side.
01-08-2014, 10:11 AM | #20 |
Did you use a compression fitting, or flair the existing lines to fit the rad.
01-08-2014, 04:21 PM | #21 |
Old member
I will have to look at it closer Friday when I'm over there. I think they just used clamps on the radiator side since the fittings where there already.
01-09-2014, 11:13 AM | #22 |
That special fitting only applies to later 4l80s though if I'm not mistaken. At some point the rear fitting changed places on the housing and required the different fitting. My 95 4l80 has no problems with a standard fitting.
And for the record, I question shops all the time. If I didn't do it myself, I question it.
Will 1968 C10 - Project Texa Go 6.0/4L80e 2003 Mitsubishi Lancer Evolution 2002 Ford Excursion 7.3L 2024 Toyota Sienna |
02-11-2014, 07:53 PM | #23 |
Old member
Well I got the old Power steering hoses off tonight and will have new ones made up to fit correctly. It will look a lot better when I'm done.
