01-05-2014, 09:31 PM | #1 |
Need Help Installing Electric Radiator Fan
I'm getting ready to put an electric fan setup on my 72 GMC. Does anyone know where I can get an aluminium Frame to fit a 16" fan or 2 10". I have a Gm 4 row Radiator. I've seen some really nice setups. Can I buy this somewhere. I did find a couple on ebay but non my size radiator. Does anyone build these? Thanks again for any help!
72 GMC 1/2 Ton |
01-05-2014, 10:47 PM | #2 |
Re: Need Help Installing Electric Radiator Fan
I had a buddy of mine build me one utilizing oem fans. Follow my build link for a look.
1969 RS/SS Z10 Camaro Pace coupe 1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218 1979 Mazda RX7 1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary 1999 Honda Valkyrie 2006 Corvette Z06 2010 BMW 650i |
01-05-2014, 11:18 PM | #3 |
Do you know if he would build another one for a 4 core radiator? Thanks Lyn
72 GMC 1/2 Ton |
01-06-2014, 12:40 AM | #4 | |
Post a request on my thread. He'll see it.
01-06-2014, 06:06 AM | #5 |
Ya might check with Wes at Classic Heartbeat.Com . He's a vendor on this forum, and IIRC, he sells fan shrouds for electric fans?
http://classicheartbeat.com/index.html
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
01-06-2014, 09:49 AM | #6 |
Your stock fan shroud and a 18" (?) electric fan from a jeep = awesome. Some say it's too loud. If you have super quiet exhaust...maybe. I run this set up with a thermostat switch. Works great.
01-06-2014, 12:16 PM | #7 |
Do you have any pics of your setup. What year Jeep fan did you use if you don't mind me asking? I've got a brand new fan shroud I bought from LMC that I haven't ever mounted up. Could you tell me which thermostat switch you went with. Thanks alot.
72 GMC 1/2 Ton |
01-06-2014, 03:18 PM | #8 |
Msgt USAF Ret
Here is one.
........http://67-72chevytrucks.com/vboard/s...d.php?t=254617
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-06-2014, 03:42 PM | #9 |
Any good radiator shop can make you a custom shroud if you are on a time restraint. Most have fans for just about any combination. Just make sure your electric fans are the slim design as space can be tight. In my application I just took the 4 core rad to him after measuring my available space. Good to support your local economy too many of the Mom n Pop shops no longer are around.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
01-06-2014, 06:35 PM | #10 |
Chance
Nice setup Wes!
1968 Chevrolet Stepside BB 396 w/TH400 1972 Chevrolet 3/4 Ton 4x4 BB 496 w/TH400 |
01-06-2014, 07:06 PM | #11 |
Fabricate till you "puke"
I run 2 -14" fans , on a steel shelf, with Painless controls. The mix kept my 383 cool, as well it will work with the 5.3? Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-06-2014, 08:35 PM | #12 |
I ran junkyard fans off of a 93 Maxima. I only had to trim the shroud slightly so that the fans would sit down right between the radiator tanks. I just drilled and tapped the top and bottom steel support for the radiator core and used 5/16's bolt to attach the fans using the tabs made to the fans.Fit real good worked great and was free except the two relays. They were two speed fans but I just wired them to the high speed only. With a 195 thermostat,stock 4 core brass radiator,stock water pump my alum headed 10.5-1 compression 355 stayed at 200 in traffic in July.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
01-11-2014, 08:06 PM | #13 |
Does anyone know if this fan is the right one to use with stock fan shroud on my 72 GMC for electric fan conversion? Amazon.com: Sunbelt Radiators Inc. New...
I got my info from this thread http://67-72chevytrucks.com/vboard/s...d.php?t=254617
72 GMC 1/2 Ton Last edited by MashTheGas 72; 01-11-2014 at 08:15 PM. |
01-29-2014, 09:47 PM | #14 |
Why do you want an electric fan. Get a 7 blade fan with a shroud and you will be fine.
01-29-2014, 09:56 PM | #15 |
I Have one! I would just like to go with electric and free up some Hp.
72 GMC 1/2 Ton |
