Old 01-05-2014, 11:36 PM   #1
hrc200x
radiator support same on a '91 quad headlights vs. single lights
Wondering if the rad support is the same on the '89 and up blazer/burb/crew cabs when they came with two headlights vs. quad lights? If they are different whats the difference?
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208.
hrc200x is offline   Reply With Quote
Old 01-06-2014, 10:33 AM   #2
D13
D13's Avatar
Re: radiator support same on a '91 quad headlights vs. single lights
Assuming you are talking the miniquad (side by side) they are different than the large singles. And those are different thant the 80's stacked (up/down) quad lights. The difference is in the light frame pockets and adjustor mounting openings for the lights.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 01-06-2014, 06:04 PM   #3
hrc200x
So this front end: http://www.pirate4x4.com/forum/attac...n-100_0065.jpg
can't be converted to this: http://67-72chevytrucks.com/vboard/a...1&d=1243560927 with out the corresponding rad support? Can't believe chevy wouldn't have allowed for both set ups in the same support.
Old 01-06-2014, 08:01 PM   #4
jitteryguy
GoatLube Experss
jitteryguy's Avatar
the head light buckets wont interchange, the quad light was made to correspond with the new '88 1/2 ton body style, the single was left over from the mid to late '80's . it was used on "work trucks" and "utility" models.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
