Old 01-06-2014, 01:37 AM   #1
Sleeperc10
Leafspring ?
Hello everyone, If i swapped out my leafs on my 71 k10 longbed would it get the truck a softer ride? I have 52" leafsprings out back now but if i did like a 60 something would i get a better ride out of it?
Sleeperc10 is offline   Reply With Quote
Old 01-06-2014, 03:54 PM   #2
gerfunken
gerfunken's Avatar
Re: Leafspring ?
Not really. Most of the time trucks aren't easy to dial in when it comes to the rear springs. In order to get a smoother ride, you give up your ability to haul stuff in the back (or, you end up carrying around a couple of bags of cement.) Now, you may be able to find some springs with a lower compression rate or remove some leafs from the spring pack, but you need to add some overload springs or go with an air-bag set up to compensate when you do carry a load in the truck, but there aren't any real guarantees.
Honestly, the best ride I've had in my truck is when I'm moving about 2400lbs of crushed granite… my truck has a great ride at that point.
-Scott
1972 Chevy K20
Picture Gallery
Build Thread
1930 Chevy AD
Picture Gallery
1929 Ford Model-A
Picture Gallery
1975 Triumph TR-6
Picture Gallery
Old 01-06-2014, 09:27 PM   #3
Sleeperc10
Re: Leafspring ?
So could I swap 56" springs in for the front and 64" springs out back? I understand Ill have to do new shackles etc. but would i be able to recenter my axles?
Old 01-07-2014, 09:58 PM   #4
Mike C
Mike C's Avatar
Re: Leafspring ?
56's in the back is easy. Get some from a Suburban. Just move hangers back 4". Get 1/2 tons springs. Just remember, length isn't everything with springs.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-21-2014, 02:24 PM   #5
twich3136
twich3136's Avatar
Re: Leafspring ?
have you found any shackles? i have a set of 99 leafs with overloads from a 2500hd with a 99 sf 14 bolt that i want to put in my 68. cant find shackles to save my life. i'm about ready to make my own. its really easier to get 56"s just remember to measure twice, 4 times is better.
USMC
SEMPER FI
68 Chevy Longhorn 350/400 factory posi
twich3136 is offline   Reply With Quote
