Which Shroud
I have installed a serpentine belt setup on the front of my motor in my 69. My original fan shroud was busted in several pieces but it looks like it is too small of a diamter to clear my serpentine fan.
I am looking for another shroud but am unsure as to which one I should get. What is the difference between one with AC and w/o AC? My truck has AC. Also what is the difference between a small block and big block shroud? I am new on this board, which by the way is awesome, and would appreciate any and all info. Thanks |
its all about the +6 inches
I can't answer all of them, but the big blcok one has the fan placed higher than a small block.
If your fan is the same size as what you had before, then a small block A/C one should do the trick. |
