01-06-2014, 12:39 PM | #1 |
Column mounted turn signal switch
So, I've been messing around with my stock turn signal switch that is a cable actuated unit on the steering column, under the dash.
These seem a little problematic as I've had to replace it twice. Am I missing something here or is this the reason everyone moves to the external, column mounted type like the one pictured below? Thanks, Scott |
01-06-2014, 01:02 PM | #2 |
Re: Column mounted turn signal switch
Don't see too many switch to the Signal Stat type.
You can, however just change out to a '63-66 column. Those switches are easily available and dependable. |
01-06-2014, 02:51 PM | #3 |
01-06-2014, 04:23 PM | #4 |
01-07-2014, 09:02 AM | #5 |
Im thinking the 63-66 guts will fit our 60-62s.
