Old 01-06-2014, 04:23 PM   #1
1970 C10 MJW
1970 C10 MJW's Avatar
low oil pressure:(
I bought an 03 tahoe lt 5.3l flex model in August I put over 10,000 miles on it since then. strangely every time I have changed the oil my pressure has gotten worse until the most recent time its now showing under 10 at regular temp on idle, mind you i have even gone to a heavier weight oil and have changed my oil pump with no change in pressure... I am pretty sure I have a bad main bearing, just want to see what other guys have to say, I am obviously no longer driving it (before you guys ask) I did change the oil pressure sender and I had a buddy with a super fancy computer scanner check the pressure from the obd2 and it confirms dangerously low oil pressure.
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 01-06-2014, 09:06 PM   #2
Special-Ed
Special-Ed's Avatar
Re: low oil pressure:(
just hook a manual gauge to it find out for sure
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 01-06-2014, 09:19 PM   #3
buddy_1
buddy_1's Avatar
Cast iron or aluminum block?
I know the "VOICES" aren't real but they have some great ideas.
1978 GMC Sierra Classic C25
1983 Datsun 280ZX Turbo
1997 Chevy Cheyenne K2500
1999 Polaris Sport 400
buddy_1 is offline   Reply With Quote
Old 01-06-2014, 09:29 PM   #4
1970 C10 MJW
i know the pressure is low, but thanks for the input cast iron
Old 01-06-2014, 09:37 PM   #5
1970 C10 MJW
Sorry not trying to sound like a jerk lol, but i know its low,and its a cast iron block
Old 01-06-2014, 09:49 PM   #6
buddy_1
buddy_1's Avatar
There is a pressure relief valve in the oil pan just above the oil filter that can release pressure before it gets to the sensor. Is the engine noisy or just low pressure? Checking specs in Service Information shows:
•Oil Pressure – Minimum – Hot
Metric
41 kPa at 1,000 engine RPM
124 kPa at 2,000 engine RPM
165 kPa at 4,000 engine RPM
English
6 psig at 1,000 engine RPM
18 psig at 2,000 engine RPM
24 psig at 4,000 engine RPM
Old 01-06-2014, 09:51 PM   #7
1970 C10 MJW
makes a lifter tick, and how do i check/replace that valve?
Old 01-06-2014, 10:13 PM   #8
buddy_1
buddy_1's Avatar
Well I think I have to correct myself, the 03 doesn't show the valve I mentioned before. It's used on the engines with Active Fuel Management. When you replaced the pump did notice a hex headed bolt/plug above the oil filter inside the pan?
Old 01-06-2014, 10:19 PM   #9
1970 C10 MJW
i didn't drop the pan, I also do not have AFM
Old 01-06-2014, 10:25 PM   #10
buddy_1
buddy_1's Avatar
Well one thing that can cause low pressure would be a pinched or damaged pick-up tube o-ring/seal.
Old 01-06-2014, 10:28 PM   #11
1970 C10 MJW
the pickup tube i believe is ok because it had good pressure before, and the seal was replaced when i changed the pump, the pressure shows the same now as it did when I had the old pump in
Old 01-06-2014, 10:32 PM   #12
buddy_1
buddy_1's Avatar
OK when does it make the valve train noise?
Old 01-06-2014, 10:33 PM   #13
buddy_1
buddy_1's Avatar
All the time, worse at certain rpm's?
Old 01-06-2014, 10:35 PM   #14
1970 C10 MJW
always, when its cold with a lil higher oil pressure its a lil quieter...
Old 01-06-2014, 10:36 PM   #15
buddy_1
buddy_1's Avatar
Is it counting any misfires?
Old 01-06-2014, 10:38 PM   #16
1970 C10 MJW
no misfires
Old 01-06-2014, 10:40 PM   #17
1970 C10 MJW
oh and i just changed the lifters about a week before i changed the pump
Old 01-06-2014, 10:48 PM   #18
buddy_1
buddy_1's Avatar
All you can do now is plasti-gage the crank bearings. I have had some that the cam bearings caused the same symptoms. That's why I asked about the block earlier, I had one with aluminum block that spun #3 cam bearing out of the block. How many miles on this motor? Just remembered another one I had that acted like yours that had a lot of loose carbon floating around in the pan. While it was running the pump screen would slowly stop up with the carbon. Cut the engine off for 5 minutes and it be good for a few more minutes.
Old 01-06-2014, 10:51 PM   #19
buddy_1
buddy_1's Avatar
What did the rollers on your old lifters look like?
Old 01-06-2014, 10:53 PM   #20
1970 C10 MJW
130,000 and its when the blocks warm, if i leave it sit for 2 hours the pressure will still be low, and like i say ive changed the oil a few times so i figure stuff in the pan would be gone, i use castrol syntec and k&n oil filter first time, mobil 1 filters now
Old 01-06-2014, 10:56 PM   #21
1970 C10 MJW
the old ones looked fine
Old 01-06-2014, 11:02 PM   #22
buddy_1
buddy_1's Avatar
Time to pull out the plasti-gage to see how loose the crank is. Just be careful, got a feeling your gonna need cam bearings also.
Old 01-06-2014, 11:04 PM   #23
1970 C10 MJW
thanks buddy thats what i was thinking bout the mains
Old 01-06-2014, 11:16 PM   #24
buddy_1
buddy_1's Avatar
Hope I was some help, let us know what you find. Good luck. Buddy
Old 01-06-2014, 11:22 PM   #25
1970 C10 MJW
sure will
