Old 01-06-2014, 09:02 PM   #1
ShinyC10
overdrive blowing fuses
Just threw in a new 700r4 tranny and everytime I hit that overdrive, it blows my radio fuse an d shuts off my Dakota Digital gauges. Anyone care to take a shot at what's going on?
ShinyC10 is offline   Reply With Quote
Old 01-06-2014, 09:40 PM   #2
sean1969c10
sean1969c10's Avatar
Re: overdrive blowing fuses
Are all these things on the same circuit?
Sean
"If your gonna be dumb, you gotta be tough"
1960 Chevy Impala Sedan - my 25 year search is over!!
1969 C-10 longbed - Nice day DD
1970 Chevy Nova - Street and Strip Project
2002 Acura MDX my DD
2007 Honda Odssey - My Wife's "Mommy Van"
sean1969c10 is offline   Reply With Quote
Old 01-06-2014, 09:45 PM   #3
ShinyC10
No they are not
Old 01-06-2014, 10:12 PM   #4
sean1969c10
Ground short? Seems like they must have something in common.
Sean
Old 01-07-2014, 11:09 AM   #5
Rich84
Rich84's Avatar
Weird...Just guessing.. But could it be when it goes into lockup it blows the fuse??
I think it's a purple wire at the brake switch that provides 12v to the lockup solenoid. Disconnect it and see if it still blows the fuse. The converter won't lockup without the 12v.
Like previously stated 90% of the time there is usually a problem with a ground causing problems.
Rich84 is offline   Reply With Quote
Old 01-07-2014, 06:52 PM   #6
ShinyC10
Found out the problem! The previous owner had somehow switched the pins to the connector. They had swapped the hot wire and the ground, ultimately leading to continuous blown fuses. Thanks for the help guys!
