![]() Join Date: Jan 2012
Truck wont start
Went out to start the truck this morning and it wouldn't start. Turn the key and absolutely nothing happened.
The headlights come on and the tail lights work. When I turn the key it is like turning a disconnected key cylinder. When you turn the key the first click, everything powers up, I don't get any of that. Does the key cylinder just go bad? All of a sudden?
Matt Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655 "Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!" |
Re: Truck wont start
Is it an automatic? The neutral safety switch will do that. Move the shifter a little, more towards reverse. Also the ignition switch itself can cause problems. Other than that check all connections.
2005 GMC K2500HD D/A 1993 GMC K1500 2011 Subaru Legacy. 2013 Subaru Outback 1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot. ![]() |
Probably should have noted that. It is a 3 speed on the floor.
Could be the ignition switch, I had mine go out twice in my truck. Just a pain to get the assembly out.
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
![]() Join Date: Dec 2012
Have you checked the battery cable ends? They may have corrosion keeping it from starting. Just a guess.
Good luck!
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
I am leaning towards the ignition switch. Battery terminal ends are good and the battery has a good charge.
Is there a way to jumper the ignition wires just to see if it is the switch? I guess that would be hot wiring it for all the LEO's out there. ![]()
Check your positive cable at the starter. My Blazer was doing the same thing this past summer, Turned out the Starter solenoid was intermittent, and eventually failed. Had power to everything else. My 2 cents.
Check the small wire that goes from the positive bat terminal to the junction block on the pass fender. mine broke loose one time and it did the same thing...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
watching this one. I'm having some similar issues, but have complete power loss.
One good place to check would be the fuse block, I had similar issues except it was everything that turns on with the ignition switch and when I unbolted the fuse block it turned out to be a bad connection there
Austin 2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked) 2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l |
#11 | |
So... a quick trip to the parts store and a new switch and we are back in business. Thanks to all for the suggestions, and, I did look at each of those to make sure they were up to par. ![]() Here is my homemade ignition switch tester. Yellow to BAT, Blue to IGN and touch the other Blue to SOL = Engine Start. ![]()
Matt Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=672655 "Father thank you for the gathering of friends, Father we give thanks for all the choices we've made because that's what makes us who we are, let us forever cherish the loved ones we've lost along the way and most of all THANK YOU FOR FAST CARS!" Last edited by ekgguy; 01-08-2014 at 05:24 PM. |
