01-07-2014, 06:36 PM | #1 |
Old member
Brackets
I have a complete set of factory GM small block AC brackets. The picture shows the oringal bracket cut which is how I got it. I made another one at work so you will get both. For just the AC brackets I would like $200.00 + shipping if you want the pulleys and all the front of the motor stuff the $300.
That will be alternator brackets, AC brackets and the pulleys except for the power steering pulley. I also have a set of Corvette valve covers for $120.00 + shipping. I have the oil spout to go with it. They need to be cleaned up though. if you want a complete TPI stand alone system I have one of those to.
02-02-2014, 10:11 PM | #2 |
Old member
Re: Brackets
TTT
These come complete with all the stuff to make a small block engine run. AC internal regulator alternator, water pump I'll even throw in the P/S pump and brackets along with all the pulleys . Everything. + shipping.
