Old 01-08-2014, 01:08 AM   #1
Stewy49
AD Grill
Is the grill from a big truck like 1 1/2 ton different than a pickup's? Thanks for any info.
Stewy49 is offline   Reply With Quote
Old 01-08-2014, 02:06 AM   #2
torchlight
torchlight's Avatar
Re: AD Grill
Yes, I believe the grille bars are thicker vertically, and the grille support frame is different as a result. Same width, though, I believe.
Build Thread: "Marvin" (1953 3100)
torchlight is offline   Reply With Quote
Old 01-08-2014, 11:22 AM   #3
alaska gasser
alaska gasser's Avatar
Re: AD Grill
The grill will fit, but 1/2 ton support brackets are needed. I did that on my panel I used to have.
http://67-72chevytrucks.com/vboard/s...d.php?t=592642 '48 Chev extended cab with attitude
http://67-72chevytrucks.com/vboard/s...d.php?t=592769 My daughter's '46 International PU
alaska gasser is offline   Reply With Quote
Old 01-08-2014, 11:29 AM   #4
mr48chev
mr48chev's Avatar
Re: AD Grill
Each bar will only go in the space it is intended for. The middle three bars have notches on the back to show second third or 4th bar. That is if you are mixing and matching pieces from several grills.
My ongoing truck projects:
Old 01-08-2014, 05:02 PM   #5
S10Fan
Old Heap Driver
Re: AD Grill
Yes, they're different. I have a pair of support brackets for the big grill, excellent condition. That's how I learned the difference. LOL.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
